Cooper (non S) Modifications specific to the MINI Cooper (R50).
what's this
Old Jul 4, 2006 | 10:05 AM
phillyunderworld's Avatar
phillyunderworld
what's this
this thing actually looks like it could work. not exactly a turbo, but it's gotta give you something. right????
http://www.electricsupercharger.com/index.shtml
Old Jul 4, 2006 | 10:55 AM
sandtoast500's Avatar
sandtoast500
Hmmm, I usually laugh at stuff like this but I see the point here. Good FAQs and testimonials.
I guess it would all depend on how our cars would interpret the increase in air pressure. If it would dump in more fuel, would it completely combust? Would it just bottleneck in the head? Aren't all the cylinders burning as much fuel as possible on WOT anyway?
I don't even think that thing would fit under my already cramped bonnet.
Old Jul 4, 2006 | 11:01 AM
phillyunderworld
i think it would fit perfectly in between my k&n filter and the cod air intake pipe
https://www.northamericanmotoring.co...ad.php?t=66443
Old Jul 4, 2006 | 11:15 AM
sandtoast500
Depends on whether u can fit all that stuff inbetween the filter an pipe. Maybe some cutting and shortening along with some rearranging.
Old Jul 4, 2006 | 03:31 PM
xxTHIR13ENxx's Avatar
xxTHIR13ENxx
This is actually very interesting.
I think that if you take off the filter you have, you'd then have the space needed for the installation. I believe the new "e-Ram" comes with its own filter, right? So you could use the air-intake pipe with the new "e-Ram" filter. (?)
And I think my air-intake has more room than the one pictured above:
I'd be a good candidate to try this!! lol. I'd rather wait 'til somebody does it first, then bite the bullet. But 300 bucks for about 15hp is not a bad idea at all!
Very interested and I'll keep an eye on this thread, I'll tell you that.
Take care,
Leo.
Old Jul 4, 2006 | 03:37 PM
phillyunderworld
it will definitely fit. i don't think that is even a question . i think the real question is will it make a noticeable improvement when the throttle is all the way open ,or will it f@#k the computer up up because of the added airflow
Old Jul 4, 2006 | 04:47 PM
namwob's Avatar
namwob
Stop it. That thing will rob hp by blocking the intake charge air flow which is much greater than the miniscule volume that crap could produce. So please don't worry about how it will fit. That would be worse than inserting a cigarette lighter powered tire inflater in your air filter (hey mines 40 psi instead of 1.7 psi like theirs) That could bring me close to 500hp except, like their product, it doesn't work. Sorry
Old Jul 4, 2006 | 05:00 PM
phillyunderworld
http://www.electricsupercharger.com/...dyno/eRAM1.pdf
Old Jul 4, 2006 | 05:05 PM
Jim Ray's Avatar
Jim Ray
It is a $300 horsepower reducer.
Old Jul 4, 2006 | 05:07 PM
phillyunderworld
did you read the link above? about the civic and all?
Old Jul 5, 2006 | 02:35 AM
Jim Ray's Avatar
Jim Ray
Yes.
Old Jul 5, 2006 | 07:29 AM
Flyer's Avatar
Flyer
Do you believe everything you read on the internet?
Old Jul 5, 2006 | 07:34 AM
mdsbrain's Avatar
mdsbrain
Isn't that cute. They put a desk fan in the intake pipe
Old Jul 5, 2006 | 07:40 AM
Dr Obnxs's Avatar
Dr Obnxs
I worked the #'s and this thing should work.
to all the skeptics out there, a 1 PSI increase in ambient air pressure would be about a 6% increase in total power output. And no, the car won't puke on this either, as it figures out what to do based on the pressure and temp of the air charge in the intake manifold. Think of it as having a Mini in Denver, then driving it at sea-level.
Axial fan technology is no joke. Just because a bunch of people say it's can't work because it's a web add should really start thinking more about the theory of operation of our cars.
There's a previous thread about this floating around somewhere, and it evolved pretty much like this one is.
Look at this thing. Wonder if it works?
Hah, I saw something similar on eBay for $29.95. Effin joke to make someone (not you) rich.
Naw, sounds like a good idea.
NFW! Can't work, and would choke the heck out of the intake path.
But the numbers work out!
I don't care about the numbers, this CAN"T work.
Long and short, even if you say that it'll rob 1-2 HP to turn it, the chemical energy released by buring more fuel will create more than the 1-2 HP to run it. This is EXACTLY the same priciple used on the S with the Roots SC, and in a way, is a baby twincharge kit.
Frankly, I have no idea why this gets such universal derision whenever it's brought up. It has the potentail for much more bang for the buck than most mods contemplated by the Mini crowd.
Matt
Old Jul 5, 2006 | 10:30 AM
sandtoast500
well, the thing does spin at 24,000 rpm in a tenth of a second...
it's gotta condense some air...
Old Jul 5, 2006 | 12:39 PM
phillyunderworld
it will definitely work when the throttle is full open. better than what your engine is pulling right now. but if your just cruisin,it will be a bit more restrictive, because the thing only turns on when the throttle's fully open. i 'll be getting one soon so i will let you know my results. this isn't some pice of internet crap though. if i'm wrong then i'm wrong. it comes with a dyno test gaurantee though so how could you go wrong.
Old Jul 5, 2006 | 03:08 PM
Dr Obnxs's Avatar
Dr Obnxs
Just look at the air it moves.
It's over a 1000 cfm fan! It has to heat the air less than about 20 degrees C to actually provide densification. On the S there's tons of room to try one....
I'm very curious....
Matt
Old Jul 5, 2006 | 03:19 PM
sandtoast500
but u can densify thru anyone of the variables, temp, pressure, or volume, right?
Old Jul 5, 2006 | 03:30 PM
Dr Obnxs's Avatar
Dr Obnxs
Yes....
But when you compress, you heat, no matter what. If the fan is very efficient, you don't heat it more than you have to. If you have an inefficient fan, you create more heat than density (BTW, the roots blower we useon the S isn't that efficient, hence the intercooler).
so, for this fan create power, it has to provide an increase in molecular density, and that is proportional to the absolute pressure divided by the absolute temp.... If it gives you 1 psi of pressure rise in front of the TB, then as long as the temp rise is less than ~18 C, the molecular density increases, and you get more power.
Matt
Old Jul 5, 2006 | 03:39 PM
sandtoast500
MAN, I love this stuff! THANK YOU, DOCTOR!
Does anyone alse love this stuff?!?!?!?
This is great.... Let's slap that mother on and see what she can do!
Old Jul 5, 2006 | 07:02 PM
sandtoast500
here's some more good reading info
http://cgi.ebay.com/ebaymotors/eRAM-...spagenameZWDVW
and HOLY CRAP?!?!!?!? WATCH THIS: :impatient :impatient
http://video.google.com/videoplay?docid=-2935357979005483067&q=928+video
Where do these crazy friggin people learn how to DRIVE!?!?!?!?
One of you seasoned race veterans please tell me this is how most racing in this class goes down... I've watched a bunch of onasleds videos, among others (his are easily accessable! thanks & good luck! ) but I've never seen this sort of craziness. talk about early apex!
Old Jul 5, 2006 | 08:03 PM
namwob's Avatar
namwob
Now that I see more info. on this product Its feasible that it could work. But you still have the issue of restrictor plate or lag when not powered up, which is most of the time. Thats on your side as far as 2600rpm motors bearing life is concerned. I'm also not to wild about the 60 AMP drain on the battery & alternator. Ouch. Also when it eats itself, where do you think all those little peices end up? Just kidding!
Old Jul 6, 2006 | 07:19 AM
Dr Obnxs's Avatar
Dr Obnxs
While you point out valid concerns..
there is data showing that the unpowered state isn't a flow restriction, and there is lifetime data as well.
Matt
Old Jul 6, 2006 | 01:41 PM
phillyunderworld
Matt
even better then. you hit the nail on the head when you said this might be one of the best mods for a cooper for under 300 . no way to tell for certain yet, but i emailed the company and i should have one in about two weeks.i wonder if this will effect the mth tuner file?
Old Jul 6, 2006 | 03:33 PM
namwob's Avatar
namwob
He's going for it. Good luck, I'm keeping my fingers crossed.
