Cooper (non S) Modifications specific to the MINI Cooper (R50).
Engine mods: ideas and ?
Old May 25, 2006 | 12:40 AM
  #26
Maaij's Avatar
Maaij
What cylinder head should I get for my Cooper:
- Cylinder head, ported and polished-standard valves
- Cylinder head, ported and polished-big valve head
I am not too worried about the price difference but it must give me the best performance. Do I need some modification if I want a big valve head? I mean, is the fitment of a standard valve head the same as a big head (no other mod needed)?
Old May 25, 2006 | 12:52 AM
  #27
Maaij's Avatar
Maaij
This head looks interesting;
http://www.minispeed.co.uk/new_mini/...ct&id=head-std
Price is pretty good. What do you guys think?
Old May 25, 2006 | 03:05 AM
  #28
SpiderX's Avatar
SpiderX
I have never driven a modified Cooper but after reading this thread I am interested.....without the parasitic drag of the SC.....I'll bet the throttle response is very good......
Old May 25, 2006 | 03:08 AM
  #29
SpiderX's Avatar
SpiderX
there is another thread about MTH which talks about the merits of larger exhaust valves......seems the consensus is that is the bottle neck.....I have large valves on my MCS and it runs strong......
are there no issues with putting an MCS head on a Cooper?
I have never thought about the diff of the throttle response but with no SC I'll bet i is much snappier.......is that so?
Old May 25, 2006 | 06:33 AM
  #30
scobib's Avatar
scobib
Oh, it's VERY snappy...
All the MINI heads are the same... the S head does have better valves (Inconel vs. crap metal), so it is preferable for a base to start the port/polish process (IMHO) if you plan to re-use stock valves. All the OEM MINI cams have the same profile, too.
I do not think that MINI screwed up with the sizes of their valves - and especially not so on the Cooper. The S may benefit from larger exhaust valves, but I can't see the Cooper getting much more of a benefit.
Once you see what's behind the valves, you'll see just how much room there is for improvement... removing that material will make a HUGE difference in flow in and of itself.
If I had an S, I would have opted for bigger valves to complement what other mods I would have - pulley, etc. But, since I don't have an S, I don't have to worry about that...
Some things to consider if you go with big valves... IMHO, it's necessary to upgrade the valvetrain at the same time with bigger valves. This means new retainers, shims, springs. Also, note that you will have to pay for a valve job - the seals will need to be re-cut for the new valves.
The Schrick cam for the Cooper is GREAT... smooth idle and great range!
Old May 25, 2006 | 09:50 AM
  #31
Dr Obnxs's Avatar
Dr Obnxs
Yes...
The volume of air between the TB and the intake valves is much smaller on the cooper than the S. This is the basis for the difference in throttle response.
Matt
Old May 25, 2006 | 10:58 AM
  #32
cristo's Avatar
cristo
Alliance Member
Matt
Also figure in the 18# flywheel for the MC vs the 28# flywheel for the MCS.
Old Jun 30, 2006 | 06:31 AM
  #33
Mini Toy's Avatar
Mini Toy
JCW Head?
Would there be any worthwhile gains to be had for a factory JCW MCS to remove the head and do a clean-up on the CNC P&P done by JCW? What about doing an extrude hone & port matching vs. another port and polishing job done by a good vendor shop? Thanks for your feedback.
Larry
Old Jun 30, 2006 | 07:34 AM
  #34
SpiderX's Avatar
SpiderX
After giving this some thought if you eally want more power sell and buy a used MCS...... "halon and nomex engaged" ...... TB will be a waste..... getting mods to integrate can be a nightmare...... it is not as easy as bolt on and go..... a head with big valves may not be what you need but rather a cleaned up head..... I really think you might consider an MCS for that kind of money you could #1 make a mess (I have been there and it can cost lots to fix) #2 have a very nicely integrated factory car with warranty if you buy right..... if you can afford it you get an 05 with the new gears and your set.... #3 leave you engine stock .... improve your suspension and brakes......take driving schools and give your friends with MCSs fits
Old Jul 1, 2006 | 03:53 AM
  #35
Bullfrog's Avatar
Bullfrog
I like Spidey's #3 -
leave your engine stock .... improve your suspension and brakes......take driving schools and give your friends with MCSs fits
Oh, and tires.
Old Jul 1, 2006 | 05:14 AM
  #36
goin440's Avatar
goin440
Larry
I haven't seen the stock head to compare, but from what I can tell on the JCW head, only the exhaust ports have been smoothed. My brother has a neon with a full-race ported head and its a work of art. Enlarged, smoothed intake and exhaust and what I suspect, very good flow. BTW, comparing MINI heads to Neon heads is like looking at a slightly larger identical twin.
The work on the Neon head even included larger valves for a grand total of about $850. It pays to find a reputable shop... one that the venders probably source anyways
Old Jul 1, 2006 | 03:14 PM
  #37
xxTHIR13ENxx's Avatar
xxTHIR13ENxx
Oh, and tires.
Hey people, thanks for keeping this thread alive. I haven't checked it in a while, sorry.. lol...
I third-agree on that, but the thing is - that's done. Aside from the driving school (but does Karting school count?).
I've finished 99% of my exterior/interior changes, I'm 100% done with suspension and brakes, all I need now is more power. I'm about 30% into the power-upgrade, with intake and exhaust, but I still have big plans for the little guy...
So as I thought before, my goal is to get the ALTA headers (that's for sure), then I was (and still am) debating about the M7 Throttle Body (for the right price, I might do it...), and the ECU upgrade. Those are for sure. I just wasn't sure if I should go for a cylinder head, as well. I know that would be the best thing to do to get power, but I'm not sure I got the funds all at once... I did talk to my mechanic-guy and we came up with some numbers: for a polished & machined cylinder head + Shrik camshaft (check spelling), and installation - $2500. That's reasonable, but it's still way more than I could afford right away.
Thanks for the comments though.
Leo.
PS: Please don't tell me "sell your car and buy an S", because I hate that. If you wanna know why I chose the non-S to begin with, please ask, but don't assume I'm not happy with the car and want something else, please.
Old Jul 2, 2006 | 12:31 AM
  #38
Dr Obnxs's Avatar
Dr Obnxs
After over $10k in mods...
I'd have to say save your $ and get a head when you can. Other than a pulley, the head is the key to unlocking power. So you can etiher nickel and dime your self to death on adders that don't do very much, or you can spend for the head and really unlock the power potential of the motor.....
After you've done that, all the other adders will have a chance of adding more power.
Matt
Old Jul 2, 2006 | 12:32 AM
  #39
Dr Obnxs's Avatar
Dr Obnxs
Matt
  #40
Dr Obnxs's Avatar
Dr Obnxs
Matt
Old Jul 2, 2006 | 12:36 AM
  #41
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
Matt
Dr Obnxs: Tripple reply there!
I am thinking that the head is the key to both the MC and MCS!
TREX
Nov 2, 2019 07:31 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
minipopkart
Aug 13, 2015 05:22 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
