Cooper (non S) Modifications specific to the MINI Cooper (R50).
Valeo Clutch?
Old Oct 3, 2012 | 12:25 PM
scottwrightF1's Avatar
scottwrightF1
Valeo Clutch?
Hi,
I am about to do the transmission swap from my 2002 MC 5 speed to the 6 speed.
I was wondering if the R53 Valeo and flywheel clutch will work into my R50 with the 6 speed transmission? I cannot find any information on this.
Please let me know thanks.
Old Oct 5, 2012 | 07:00 AM
scottwrightF1
Wow, nobody?
I was told to use the R50 clutch to install into the 6 speed trans to put in my R50, but not sure which flywheel to get from R50 or R53.
Anyone know?
So I guess I will look around for a R50 Valeo clutch.
Let me know thanks.
Old Oct 7, 2012 | 05:56 PM
scottwrightF1
Okay,
I was told to use the R53 clutch and flywheel to put into my R50 with the 6 speed. So I think I am clear on that now.
Thanks.
Old Jan 23, 2013 | 02:19 AM
1SuperCooper1's Avatar
1SuperCooper1
Hi Scott.
We´ve done the swap on our two R50, and you can put the Valeo R53 kit with no problem. It´s a single mass flywheel with springs clutch discs. You will notice it softer than OEM R50 clutch.
I think you know all the parts you need to do the swap, but here´s listed again:
R53 6-spd gearbox (in Europe is better ´05-´06 gearbox because is closer, I don´t know there)
R53 Driveshafts (x2)
R53 Complete clutch and flywheel
R53 Engine and gearbox mounts
R53 Starter
R53 gear **** (or another)
R53 gear lever base and bowden wires (x2)
In my opinion is the best mod that can be done to a Cooper, much more better than modyifing and tuning the engine. If you can put a Torsen type diff at the same time. Wow.
Old Jan 23, 2013 | 07:53 AM
scottwrightF1
Originally Posted by 1SuperCooper1
Hi Scott.
R53 Starter
Thanks, I was about to start on the swap this week or next week.
I thought I can reuse my stock 2002 condition "A" gear box and use the 6 speed cables which is this: #25-11-7-531-707 and 25-11-7-531-708. Hope this is okay to use my stock condition "A" gear box?
I am little concerned about the wires what need to be done or what I need. My 6 speed already came with the transmission Backup Light Switch part #123117527716. So I am not sure what is "bowden wires" (x2)?
I have the 2005 6 speed transmission and just installed the OBX LSD. I cannot wait to do swap the transmissions, but the cold weather here is terrible.
Old Jan 23, 2013 | 08:10 AM
1SuperCooper1
The bowden wires are the same parts you have listed: 25-11-7-531-707 and 25-11-7-531-708. Sorry but I don´t know their names in english.
What i don´t know is stock condition "A" gear box. Maybe a 2002 Cooper S gearbox?.
Old Jan 23, 2013 | 08:21 AM
scottwrightF1
Oh okay, so that what you mean "bowden wires" refer to "shifting cables". I am clear on that now thanks.
The condition "A" gear box in the early model has the white reinforcement ribs and the later model has the condition "B" black smooth box.
I believe that the white condition "A" box are use in the same Mini Cooper "Base" and "S".
Just curious, did you have to do anything modify the electrical wires?
Old Jan 23, 2013 | 08:26 AM
1SuperCooper1
I don´t know what is the condition A and condition B reinforcements or black smooth box. Can you post a pic please?. I´m very curious about it.
I didn´t need to modify anything on the electrical wires. I suppose dou you talk about the rear light switch. In european cars is just to plug&play with all of necessary parts.
Old Jan 23, 2013 | 08:37 AM
scottwrightF1
Here is a picture of the white condition A and black condition B boxes.
Okay, I was not sure about the wiring cause I saw somewhere that someone did some wiring modify.
Old Jan 23, 2013 | 08:46 AM
1SuperCooper1
Ok, I know what is. I don´t know which we used in the Cooper, but in the One we put a racing item as you will see attached. Very quick and totally accurate gear changes
Old Jan 23, 2013 | 08:49 AM
scottwrightF1
Oh wow, I never see that before. Just curious if there is a link for this?
Old Jan 23, 2013 | 08:50 AM
1SuperCooper1
Of course. Here it is: http://www.cae-racing.com/shifter_mini.htm
Old Jan 23, 2013 | 10:20 AM
scottwrightF1
Thanks, that shifter looks smooth and interesting. I am gotta skip that and dont want to spend that much money.
Thanks for the help.
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
