First MINI Mod -- Short Shifter (craven vs alta)
I'm looking to add a short shifter kit to my '10 Cooper.
So far it's between the ALTA Short Shifter and the Craven Speed Shifter.
If you have either of these installed, or can recommend one over the other, please share your feedback and experience(s). Thanks in advance!
Don't forget to consider the Helix:
Simple, inexpensive. It's probably the most widely used one on the market.
http://helix13.com/mini/products/suspension-chasis
^ that link also says "R53." If it can be used for the R56 the site should be updated.
I have the ALTA SSK along with the cravenspeed shift well cover. I love how it feels and how adjustable it is, but if you really need something that adjusts quickly, I'd get the CS SSK. I just think the ALTA one is made a little better IMO. I can't tell you how many compliments I get on the looks of ithe setup I have.
Yep. Where that collar is, there are 3 screws. Loosen the screws and you can slide the shifter up and down. The only thing is I don't think ALTA makes them anymore, but I'm sure you can find one in the marketplace.
I found several http://www.vividracing.com/catalog/a...r-p-45367.html and http://www.hpautoworks.com/index.php...oducts_id=3169... just google "AMP-INR-112". Now just to find out who can offer be the best price
I have the Craven Speed adjustable short shifter with well cover and JCW CF shifter. Been on the car for about 1.5 years. The SSK has always been set at the lowest setting. I love this combo. It's probably my favorite mod on my car.
Since ALTA took the ssk off their site, does anybody have the instructions saved or a link to one online? I know the general process with removing the heat shield / dust cover, linkage cables etc, but if I could find one specific to their kit it'd be nice to have them point out each detail on the part. I just picked up a used one so I'll be installing soon..
Check out the 'How To' section over at OutMotoring.com... Aaron has quite a collection of instructions, including Alta SSK (Gen 1 and Gen 2) and B&M SSK.
http://www.outmotoring.com/pages.php?pageid=3
I'm too about to decide between the Alta or Craven short shifter, but would like to keep both the stock **** and boot.
I'm wondering if the stock boot would still allow me to adjust the throw "on the fly" without having to remove anything (the boot for a start)
Anyone with such a setup?
I've installed and used both the Alta and the Craven. I highly recommend the Craven over the Alta. Mainly cause the Craven is much easier to adjust with the ****, the Alta has the screws that you will have to get a wrench to loosen and adjust, also those screws can come loose which I've seen happen.
Go with the Craven
http://www.waymotorworks.com/cravens...5-r56-r57.html
Go with the Craven
