best first mod?
Since it's just a cooper start with our Intake, it has some good performance gains, and a killer sound. Plus it's affordable.
http://www.waymotorworks.com/way-ddm...ntake-r50.html
The other biggest mod would be a rear swaybar. The Hotchkis 19mm would be perfect.
http://www.waymotorworks.com/h-sport...-bar-19mm.html
Hey WMW - when I click on the MP3 I keep getting a permission error:
Forbidden
You don't have permission to access /files/sound_clips/drive_3.mp3 on this server."
Would love to hear what the intake sounds like!
Forbidden
tires
a good set of summer tires will make the biggest impact for handling.
I/H/E obvious for power
upgraded suspension would be after tires
You might want to strenghen some weak spots first...
strut tower reinforcement braces (prevent possible damage from pot holes)
http://www.waymotorworks.com/custom-...nt-plates.html
Engine stabilizer (not so jerky when first taking off or reverse)
http://www.vipcustomparts.com/minicooperparts.htm
Don't know if it gets hot where your at
air plate diverter (more efficient flow thru radiator)
http://www.m7tuning.com/parts/produc...roducts_id=150
That's what I've done so far... the stabilizer has been the most noticable.
Also put 12mm spacers on to push the stock wheels out a bit (should of went with 15mm).
The best performance mod for a Cooper is a rear swaybar, without a doubt. Increasing power is difficult and expensive, but improving handling is cheap and rewarding. I've seen several people spend considerable amounts of money trying to make their Cooper faster in a straight line to little avail.
Also, you should think about doing some sort of mod that prevents mushrooming of the strut towers. I have the M7 version, here is a link:
http://www.m7tuning.com/parts/produc...564ea09a62f025
What size wheels are you running? Do you have the stock 15 inch wheels? If so, I threw on a set of these tires on my car and they did really well, good grip and more stability:
http://www.tirerack.com/tires/tires....EASX&tab=Sizes
And if you want to purchase a rear swaybar, I would sell you mine if you wanted it, would give me an excuse to upgrade to a 22mm rear sway
Do you know what size tire that would be? Adn yes, you def. could go with 22mm rear swaybar if you want! I have found that most people think it is too aggressive for the mini, but I think I would like the extra stiffness to be honest! I have a 19mm bar right now
GAT
Oct 4, 2015 07:27 PM
