Cooper (non S) Modifications specific to the MINI Cooper (R56).
R56 S Exhaust onto a Cooper
Old Sep 16, 2008 | 06:46 AM
jpmcc00's Avatar
jpmcc00
Hi guys...
I have recently decided to try and fit the S Exhaust onto my Cooper. I have studied the floor plans and they are exactly the same and the bolt positions are already in place on the Cooper. I'm trying to find out though if the Exhaust mod will be possible with it being from the Turbo S, should there be any side affects or will it be fairly straight forward.
Old Sep 17, 2008 | 04:23 AM
wimsaab's Avatar
wimsaab
I think yr cooper will lost some back pressure becuase the pipe size is too large for normal aspriate engine...
Lost the power in initial rpm for sure, but in the high rpm I the yr can will gain some power...
Old Sep 20, 2008 | 10:54 PM
got.pho?'s Avatar
got.pho?
i have a stock exhaust if you need it =] not for free tho =]
Old Sep 21, 2008 | 09:54 AM
jpmcc00's Avatar
jpmcc00
I think I have solved this problem, I got a local welder to make me a new end and welded it onto the Stock S exhaust, the bore size on the S is 55mm and the Cooper is 48mm, so this should solve the problem of the lost pressure.
As another mod I wasnt keen on the standard S Tips so I have had new size ends made by the same welder and these now fit the R56 Stage 1 JCW Exhaust Tips Will post pics soon
Old Sep 22, 2008 | 03:25 AM
jpmcc00's Avatar
jpmcc00
Well the modifications to get this done are truley under way so I thought I'd get the progress pictures up
First thing we found out is that the bore on the R56 S is 55mm and the bore on the Cooper is 48mm, this ment that we needed to make the S exhaust 48> mm, this was done by welding a new end piece onto the exhaust to make it fit the standard Cooper bore:
The next mod I decided to so was to make the Stage 1 R56 JCW Exhaust Tips fit the standard exhaust, unfortunatly the bore size on the tip ends was again 55mm and the JCW Exhaust tips where designed to fit 50mm, we decided to again cut a section of the end of the exhaust off and weld a new 50mm bore so this would allow the JCW Tips to fit
I also was able to source the bumper trim from a MINI2er and have the S Exhaust Brackets currently on order, hopefully will have everything fitted on Tuesday, will update with more pics then
Old Oct 8, 2008 | 02:46 PM
samroberto's Avatar
samroberto
I have a stock r56 S exhaust if anyone wants it..
It's not doing me any good lying around here, not really looking to make a profit off of it, just shake the dust off ... if anyone wants it ?
PM me if you're interested
Old Oct 8, 2008 | 03:10 PM
Oxybluecoop's Avatar
Oxybluecoop
Nice work.Now how you gonna get that MCS bumper trim on a MC.
Old Oct 8, 2008 | 03:14 PM
Oxybluecoop
The few I have seen ended up cutting the trim to fit the tips and filling the factory cutout.
Attachment 37624
Old Oct 8, 2008 | 06:26 PM
samroberto's Avatar
samroberto
or could you maybe get a stock cooper S rear valence ??
Old Oct 8, 2008 | 06:49 PM
Oxybluecoop
The MC and MCS rear valance(trim) are cut different.The easiest way to go would be a bumper swap.
Old Oct 8, 2008 | 06:57 PM
Oxybluecoop
If the OP has the JCW aero kit then yes it would be a simple swap of the rear valance.
Old Oct 9, 2008 | 04:20 PM
samroberto's Avatar
samroberto
that's what i meant, rear bumper.
Old Oct 9, 2008 | 07:06 PM
clayvt's Avatar
clayvt
Any new news as to fittment/performance?
Old Oct 9, 2008 | 07:10 PM
clayvt's Avatar
clayvt
Would a standard S rear bumper just "snap" into place on a nonS? like perhaps this one?
https://www.northamericanmotoring.co...ct/1479/cat/28
Old Oct 23, 2008 | 04:46 AM
jpmcc00's Avatar
jpmcc00
Hi guys, apologies for the late replys on this thread, been busy enjoying my new exhaust, to answer the question about the rear trim, thankfully the Aero Bumpers are exactly the same on the S & Cooper, I managed to source someone who fitted the carbon diffuser and was thus about to purchase the trim from them painted Chilli Red aswell which was fantastic
Now onto the exhaust fitment following on from my earlier post, Over all the process was very simply, apart from having to get a few new extensions welded onto the standard S exhaust it was extremely straight forward.
Thankfully the holes where already in place on the standard Cooper so this solved the initial problem of how to fit the exhaust
Having spoke with a few of the techs at the local MINI Garage they advised me that the heatshield was not necessary to refit, so we stripped the cars old heatshield and trimmed it where the new exhaust would change direction
Next job to be done was cut the old exhaust off, and fit the new one in place, thankfully as above the holes for the brackets where already in place so we fitted the brackets, fitted the new trim to the bumper and attatched the exhaust using a 48mm clamp
All in, it took approx 40min to fit and here are the finished results
An extremely worth while mod, i think it finishes off the back of the car extremely nicely, if any one need any help doing this themselves I'll be glad to answer any questions
Old Oct 27, 2008 | 09:48 AM
gianni's Avatar
gianni
hello, exuse for my english I'm Italian :-)
tue tyre in this mini are 205 45 17 or 205 40 17?
hello!
Old Oct 27, 2008 | 08:23 PM
Oxybluecoop
Looks great! Now we need a sound clip!
Old Oct 28, 2008 | 03:51 AM
jpmcc00's Avatar
jpmcc00
hello!
Hi there, the alloy wheels are infact 18" Replica R90's, the tyre size I have fitted is 215/40r18
Old Dec 15, 2008 | 03:03 PM
willsblackmini08's Avatar
willsblackmini08
so do you have a MC that looks like MCS with with JCW badges?
Old Dec 16, 2008 | 04:25 AM
jpmcc00's Avatar
jpmcc00
Yes in essence. No to everyones taste but I like it, also recently fitted the carbon diffusser and carbon fibre interior trim.
These JCW Accessories are soo so tempting
Old Dec 16, 2008 | 05:08 AM
jpmcc00's Avatar
jpmcc00
Old Dec 16, 2008 | 03:33 PM
willsblackmini08
interesting, but you dont have the turbo
Old Dec 16, 2008 | 11:52 PM
pillar's Avatar
pillar
wait... i dont get it... wats your point willsblackmini
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
