Cooper (non S) Modifications specific to the MINI Cooper (R50).
"Custom fabricated" engine stabilizers!
Old Jul 23, 2008 | 10:22 AM
AliceCooperWA's Avatar
AliceCooperWA
Due to "popular" demand (1 person asked about it), I have decided to reveal my long awaited engine stabilizer mod! It took a lot of machining etc, but in the end, it works amazingly. My engine does not move at all. It also has a "preload" feature that allows you to place a preload on the rubber bushing (the dowel is slightly larger than the hole). Installation requires a rubber mallet.
On a serious note, for anyone who is not too concerned about the cosmetics of their engine bay, but more on performance, this is a really good way to get rid of that lashing that you get if you abruptly let go of the gas at 5k rpm. If you are on a ridiculously tight budget, this is the way to go! You could also use some kind of aluminum or steel tubing instead of these expensive wooden dowels to make it look "not so ghetto". BTW, they are as easy to get out as they are to put in.
And yes I know that the rubber is cracked. That is what spawned me to do this in the first place.
I would sell these, but the shipping cost would literally triple the cost! This cost me like $1.00 for each mount.
Old Jul 23, 2008 | 11:40 AM
hemiheaded18's Avatar
hemiheaded18
Nicely done! Just an FYI, taping off the bottom of the mount and filling it with Window Weld does the same thing, minus the ghetto.
Old Jul 23, 2008 | 12:14 PM
2xMini's Avatar
2xMini
Nice!
Hmmm, I wonder what "fillings" would be good to try so you get just the right amount of stiffness without adding too much NVH.
Good home brew there, might try myself before the mount bites the dust.
Just thought of a quicker cure solution, how about using a gluegun to fill in the holes (taping the bottom, of course)? Much less of a mess, pretty stiff and hardens fast.
Daniel
Old Jul 23, 2008 | 12:30 PM
hemiheaded18
That's essentially what you do with Window Weld. I'm not sure of the cure time for WW but I'm also unsure of the strength and longevity of glue compared to WW.
Old Jul 23, 2008 | 12:41 PM
2xMini's Avatar
2xMini
Yeah, I wonder about the strength of the glue also and its resistance to stress. About the curing bit though, WW seems to take a long time to cure (reading articles on the net), not sure if I can take my car out of commision for 2-3 days, since it's my daily driver.
If I go and try the glue solution (probably next year, after my warranty runs out), I'll post results.
Old Jul 23, 2008 | 01:10 PM
hemiheaded18
Plus WW isn't cheap. A tube of the goo cost about $12-15 but should enough for both the big and small mounts.
Old Jul 23, 2008 | 02:03 PM
AliceCooperWA
How about rubber cement! It would stick to the rubber pretty good and provide a bit more give than window weld.
Old Jul 24, 2008 | 08:58 AM
BoostyMINI's Avatar
BoostyMINI
This is really weird
Old Jul 24, 2008 | 10:01 PM
AliceCooperWA
To someone with purple neons...the look of this would probably drive you insane!
I do prefer it this way because it is completely reversable. The glue thing is definitely not reversable.
Old Jul 24, 2008 | 10:04 PM
AliceCooperWA
Nice!
Daniel
Just remember that heat melts the glue from a glue gun. So it might drip everywhere after a couple of hours of driving.
Old Jul 24, 2008 | 10:07 PM
BoostyMINI's Avatar
BoostyMINI
Haha, all I said was that this was a weird thread.
I never said anything about the glue.
Most likely, if I had that mount, I would do this same mod.
Old Jul 24, 2008 | 10:21 PM
hemiheaded18
Uuuuhh, I hate to break it you, but you probably do have that mount. Open the hood and check near the shock towers, it should be there. Whether or not yours is cracked or cracking, I don't know, but you very well may have that mount.
Old Jul 24, 2008 | 10:25 PM
BoostyMINI's Avatar
BoostyMINI
Thanks but I know my car better than you do. No, I do not have that mount.
Old Jul 24, 2008 | 10:31 PM
hemiheaded18
If you say so. I have an '03 and I have that mount and they didn't change until 2005.
Old Jul 24, 2008 | 10:32 PM
BoostyMINI's Avatar
BoostyMINI
Mine was built in 01/04. And I dont have it.
Old Jul 24, 2008 | 10:33 PM
hemiheaded18
Then what I've read about motor mounts is wrong.
http://www.outmotoring.com/mini-coop..._bushings.html
Old Jul 24, 2008 | 10:36 PM
BoostyMINI's Avatar
BoostyMINI
Haha well I dont know because the 04 built cars seem to be mutants sometimes
eatsleepautox
Oct 30, 2015 06:46 AM
Zettinger
Aug 25, 2015 04:04 PM
Powershift
Aug 16, 2015 05:14 PM
Emnotek
Aug 13, 2015 05:47 PM
