Cooper (non S) Modifications specific to the MINI Cooper (R50).
MINI Cooper (non-S) turbo conversion?
Old Jul 10, 2007 | 07:20 PM
CHILE_RED's Avatar
CHILE_RED
http://www.r53.co.uk/
This is a link i found.... i dont know how good this company is, but i dont really need to know cause i have a cooper S.... so if one of yall is interested go for it...
Old Jul 10, 2007 | 08:13 PM
laggy's Avatar
laggy
hummm seems rather questionable seeing as with a normal turbo setup you need to lower your compression to cope with the incresseed pressure on the cylender walls......
Old Jul 11, 2007 | 05:33 AM
miniracer1's Avatar
miniracer1
WOW this could be my dream come true ..... if the price is good i would give it a go .... maybe i will be planning a holiday in the uk soon?
great find...
anyone have any professional thoughts about this setup ???
Old Jul 11, 2007 | 05:45 AM
Loony2N's Avatar
Loony2N
I'm no pro, but before I'd do that, at least I would find out how the R56 MC and MCS engines differ when built by MINI. I'm sure if all MINI had to do was bolt on the turbo, they would. So, if other things are different, I'd be very very skeptical.
Old Jul 11, 2007 | 06:01 AM
miniracer1's Avatar
miniracer1
off course , but they have a good FAQ section on there site and can answer a lot of related questions ... i am no PRO either, so what they are talking about is like CHINESE for me....
it would be good for someone like the fireballed people to give their opinions here....or others whom have done this install before... it ceratinly is closer to my house then the USA...
Old Jul 11, 2007 | 06:02 AM
Loony2N's Avatar
Loony2N
I'm sure they will. But they are still sleeping...
Old Jul 16, 2007 | 05:51 PM
btallack's Avatar
btallack
The setup looks simple enough. I am very interested in this. I would definitely appreciate hearing how well this works from the experts though because like those above, i'm certainly no expert.
These pages seem to have more information as well as pricing: http://www.jetforcemanagement.co.uk/mct_170_turbo.htm
http://www.jetforcemanagement.co.uk/mct_200_turbo.htm
Old Jul 16, 2007 | 06:03 PM
UKSUV's Avatar
UKSUV
It only rates it about 55 HP over stock and boosts only up to 7 psi?....Shoot, for that much money a head, chip, exhaust and a few other things should yield the same amount of power.
Old Jul 16, 2007 | 06:54 PM
silver arrow's Avatar
silver arrow
55 additional hp out of a NA 1.6l motor without forced induction is a stretch. It only runs 7psi because you can't run alot of boost with a high CR without detonation. High CR, low boost set up will be very responsive.
Old Jul 17, 2007 | 05:49 PM
big willa's Avatar
big willa
Has any body tried this turbo setup or any other, I would be intrested for 05 cooper.
Old Jul 18, 2007 | 06:52 AM
justintime's Avatar
justintime
alot of honda guys tune turbo motors with highcompression. you dont HAVE to lower compression, plus it appears to only be running 7psi
Old Aug 4, 2007 | 07:38 PM
2ndhandMINI's Avatar
2ndhandMINI
People have been turbo charging or supercharging engines that weren't originally meant for it for a while. Coming from a VW background, I know there were a number of superchargers and turbos available for originally NA engines. There are also a lot of forced induction kits available for BMW M3's. I wouldn't be surprised if a lot of those conversions left the compression stock when only looking for modest gains. I'd imagine keeping the heat down with an intercooler would help the detonation a bit. High octane would also help...
Old Aug 5, 2007 | 02:22 PM
SteveS's Avatar
SteveS
The MCS engine is much stronger to withstand the loads put on it from the super charger. Some of the differences between S and non-S are:
sintered instead of forged rods
cast instead of forged crank
inconel exhaust valves
higher oil capacity pump
oil sprayers under each piston
pistons of high temperature alloy (by Mahle) for the S. Not sure what the non-S pistons are.
much stronger gearbox in the S.
It would be a mistake to super/turbo charge the non-S cooper if longevity and reliability are important to you.
Old Aug 15, 2007 | 04:30 AM
Latka's Avatar
Latka
You're right. You don't have to lower it... as long as you like rebuilding engines. Lots of "bolt on" kits out there run about 7psi, because anything much above that and you're gonig to want to intercool it... then you might as well lower the compression ratio, and once you're at that point - why not just get a MCS and let the factory worry about how it's done?
Old Aug 15, 2007 | 05:54 AM
rubyred3's Avatar
rubyred3
yeah, regardless of the engine differences, the Midland tranny has been shown to be unreliable even at stock power levels. . .
Old Aug 17, 2007 | 10:07 AM
paintunter9's Avatar
paintunter9
sounds kool to me
some one else try it first and tell us how it works
Old Aug 17, 2007 | 12:15 PM
UKSUV's Avatar
UKSUV
I have 68K miles on my Midlands and going strong....plus, I rape my transmission...
Old Aug 17, 2007 | 12:18 PM
UKSUV's Avatar
UKSUV
Intercooling it has nothing to do with kicking pistons out the side of your boosted block. That just lowers air temps not detonation inside the engine.
Why loose all your equity in your MC and trade it in for an S? I'm gonna tear the motor down and do all custom stuff....the SAME THING I would do to my new $25K MCS. Where is the monetary advantage to that?!?
Old Aug 17, 2007 | 07:20 PM
UKCoopeR's Avatar
UKCoopeR
Amen to that brother, trying to keep the stock hood too, sleeper style
Old Aug 20, 2007 | 05:08 AM
UKSUV's Avatar
UKSUV
Well...I wanted to run a CF hood and they only make a MCS version. Looks tight though.
Old Aug 20, 2007 | 07:48 AM
GOTCURVES's Avatar
GOTCURVES
Lay the carbon fiber yourself, as much moding as you do. As for me carbon fiber is in the future and it will be a MC style. I like the lower hood line of the MC. Hood front and rear bumpers maybe side skirts as well. It will be a long process but worth it I think. I just don't have any experience with carbon fiber, just fibeglass, It should all lay up the same and the mold process is the same as well. Could have a kit by the time I'm done
Old Aug 20, 2007 | 08:48 AM
UKSUV's Avatar
UKSUV
Laying CF is out of my car modding territory. I really like my CF hood. Looks alot better since I put the fender molding on. I just need to do the grill now....
Old Aug 20, 2007 | 09:06 AM
Ranzo's Avatar
Ranzo
What's up dude? Haven't posted in a while. Sounds like the car is coming along quite well! Got any up to date pics? So what's next on the list?
I am offically Mini-less now...
Got myself a GTi-R...
Old Aug 20, 2007 | 10:40 AM
UKSUV's Avatar
UKSUV
Not to high jack this thread but...not too much. Camber plates and scroth race nets for FREE..lol New too! Oh...and we also took my exhaust off so I'm running only the header and cat setup. It is ungodly loud. Sounds good though...I cant see the pic of your ride til I get home. Sweet car though!!!
Old Aug 20, 2007 | 12:27 PM
Ranzo's Avatar
Ranzo
Oh crap sorry for high jacking the thread... back to turbos on a non-s lol...
