correct tire pressure?
Old Nov 11, 2006 | 08:03 PM
Cassy's Avatar
Cassy
so I'm trying to figure out what the correct tire pressure is for my 78 Mini.
what are other people filling?
Old Nov 11, 2006 | 08:52 PM
Angel Face's Avatar
Angel Face
Wouldn't it say on the tire itself? Different tire brands might require different pressures, even if they were the same size tires.
Old Nov 11, 2006 | 10:21 PM
Cassy's Avatar
Cassy
not exactly. a tire lists the maximum tire pressure, but the recommended tire pressure depends on the vehicle.
For example, my other vehicle is Ford F250, the tires on the truck say max pressure 80 PSI. However the recommended tire pressure is 55 PSI front/70 PSI rear.
So in the same way I'm wondering what the recommened tire pressure is for the minis.
Old Nov 12, 2006 | 01:42 AM
classicfreq's Avatar
classicfreq
I agree.. you're going to have a different pressure if you have one person who has donuts and another who has low profiles..
Originally Posted by SomeWebsite
Find the air-pressure specifications for your car's tires. You'll usually find them on a sticker located on the driver's side doorjamb. Or the sticker may be in the glove box or trunk. Don't look at the tire's sidewall for the air-pressure specifications, as it lists the maximum pressure for the tire.
It depends on the tire, in the end
Old Nov 13, 2006 | 02:46 PM
Cassy's Avatar
Cassy
the tires are 145/80R10 Marshal (probably British as the car just came over in May). The tires say maximum tire pressure is 44 PSI.
The car is about 1593 lbs.
So does anyone have any ideas on correct tire pressure.
and, yes I've already looked for the sticker on the door panel, but it is gone.
Old Nov 13, 2006 | 04:37 PM
Minimad's Avatar
Minimad
roughly 28#-32#
Old Nov 13, 2006 | 06:49 PM
Capt_bj's Avatar
Capt_bj
I run 26
I run 26 - ruffly consistent with the Haynes for 165/70 x 10 wheels - wear pattern shows no serious problems after two years.
Haynes
radials front rear
in bars (1 bar = 14.5 psi)
145SR x 10 1.9 1.8
145/70SR x 12 2.0 2.0
165/60 x 12 2.0 2.1
165/70 HR x 10 1.7 1.7 (1.7 = 24.6 psi)
175/50 VR x 13 2.0 1.8
Crossply 1.7 1.6
Haynes notes these figures are for original equipment tires....may vary with other than original equipment fitment
Old Nov 13, 2006 | 08:22 PM
Cassy's Avatar
Cassy
cool, thanx guys! I'll keep those numbers in mind and see what works best
Old Nov 14, 2006 | 06:09 AM
Jdewey's Avatar
Jdewey
When you can't find a listing for a car or trailer, look at the tire for two numbers . Maximum pressure, and the load it can carry at the maximum pressure. Then do a little arithmetic, and add a safety margin.
John
John
Old Nov 14, 2006 | 07:52 AM
wrx_xb9r's Avatar
wrx_xb9r
I run #32 on the front and #28 on the rear. This gives a good balance of grip for normal driving. This works with my set of Goodyears and my set of Dunlops on 10" wheels. I have a new set of the Yokohama 13" that I need to run. Anyone have a pressure that they like on these? If not, I will start at 32 and 28.
Old Nov 16, 2006 | 04:10 AM
Minimad's Avatar
Minimad
My manual for my Clubman Estate gives 28# front 26# rear for 145-10 radials. It handles and rides better with the extra couple pounds in each.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
