$%*&*$ CHOKE CABLE!
Old Aug 26, 2005 | 09:08 PM
STLMINI's Avatar
STLMINI
$%*&*$ CHOKE CABLE!
help. this is about the 8th time this has happened to me. the **** on the choke cable comes off. i have tried and tried to be gentle with it but it always seems to break off.
is anyone else having this problem? the only solution that i have considered is installing a newer choke cable from a rover mini but that would entail too much modification for me. plus it doesn't match.
any thoughts mini people?
mike
Old Aug 26, 2005 | 09:17 PM
Rick-Anderson's Avatar
Rick-Anderson
Yes, it is a very annoying problem.
Old Aug 26, 2005 | 11:11 PM
John Smith's Avatar
John Smith
Super glue it back on???? Or Liquid Nail???
Old Aug 27, 2005 | 04:49 AM
STLMINI's Avatar
STLMINI
i've tried that with gorilla glue. there are two problems with that... first, the **** is soft plastic and when it brakes off, it crumbles. second, the what remains once the **** is broken off is a metal cable which doesn't easily bond with the plastic.
am i doing this wrong?
Old Aug 28, 2005 | 02:29 PM
OKeefe's Avatar
OKeefe
How about ...
Concur that once the plastic pulls off you are sol. And I'd concur that I just ordered one from Mini-Sport and I don't like it. But I also ordered a heater cable and that is a perfect match for what's in my 79. I'm gonna order another heater cable and just blank out the markings. I won't have the twist lock feature, but the new cable I bought doesn't have that either. Heck. a generic lawn mower cable would work....
Old Aug 28, 2005 | 05:18 PM
jean-ji's Avatar
jean-ji
This is over on MiniMania, does this look like what you need?
http://www.minimania.com/web/Item/NA.../InvDetail.cfm
Old Aug 28, 2005 | 05:43 PM
STLMINI's Avatar
STLMINI
well, one of those that can handle actual use would be great. i've bought about 8 of those in the last year. i think i'm going to try a lawn mower cable.
Old Aug 29, 2005 | 12:41 PM
Philthy's Avatar
Philthy
I guess I've bben lucky with the choke cable,but I've had terrible luck with throttle cables. The damn things get sticky on me. I've been known to carry a bungee cord and use it to pull the gas pedal off the floor. It works great,but it looks a little wonky. I've had a good cable for about 5 months now.
Old Aug 29, 2005 | 05:08 PM
OKeefe's Avatar
OKeefe
Golly gee
I have no problems cable wise with my 79
I'm feeling mighty lucky
Actually since replacing the pos battery with an optima red top, flushing the cooling system and torquing everything to where it should be my most significant problems have been bird poop and purely cosmetic rust that can be solved with 5 minutes of sanding and brushed touch-up paint.
Maybe I should shut up now
https://www.northamericanmotoring.co...cat=500&page=1
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Emnotek
Sep 29, 2015 07:37 AM
