Bolt Pattern?
Old Nov 6, 2004 | 07:33 PM
D1JL's Avatar
D1JL
Bolt Pattern?
What is the wheel bolt pattern of the classic Mini?
Did they ever use 12" wheels?
Dave
Old Nov 6, 2004 | 08:45 PM
camelpilot's Avatar
camelpilot
Dave
bolt pattern is same as the new MINI. Yes, they came in 12 inch from 1984 I think.
Old Dec 11, 2004 | 11:52 AM
Latka's Avatar
Latka
The classic Mini has a 4x4" bolt pattern. I believe that's 4x101.5 or something like that, but it's *not* 4x100.
They came with 10, 12, and at the end, a 13" wheel. I know you can get the 10s in 10x3.5, 10x4, 10x5, and 10x6 - even a 10x7 or wider if you get a "race" wheel. I think your tire sizes are limited there though - 145 and 165 are the only widths I've seen for a 10" wheel in street tires.
Old Dec 11, 2004 | 03:43 PM
Minimad's Avatar
Minimad
Latka is correct. I think 12's are generally harder to find.
Old Dec 11, 2004 | 08:52 PM
Latka's Avatar
Latka
If I was going to jump, I'd go to 13s. I've heard I'm better off with 10s though...specially for a MK I Cooper S - that would just be blasphemy to have that car with anything other than 10s. Then again, I'm planning on running AO32Rs once I get her in better shape.
Old Jan 8, 2005 | 11:54 AM
mCm's Avatar
mCm
To put anything other than 10" on a Cooper S you'd need to do some modification on the bodywork. Larger wheels would rub the inner arches.
Old Jan 8, 2005 | 03:30 PM
Latka's Avatar
Latka
I always thought that it was if you wanted to put anything wider than a 5" wheel you needed the arches. I was under the understanding that with the MKIV, Minis came with 12" wheels and the same body...the 13s require cutting though.
Old Jan 25, 2005 | 03:26 PM
mCm's Avatar
mCm
they never made a mk5 Cooper S
YaTuSabe
Aug 23, 2018 11:41 AM
buggyeye401
Oct 1, 2015 01:22 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
buggyeye401
Sep 28, 2015 04:09 PM
EVMini
Sep 28, 2015 10:20 AM
