Supercharged Classic Mini
Look awesome, wished I can test drive this car. Owned 1 of the Mini enthusiast in the Philippines
Does anybody on this board have any experience or knowledge about adding a first generation BMW MINI S supercharger to a classic Mini? I have an '87, that currently has A/C, which will be removed very soon. I have heard from some track rats that the supercharger modification is fairly straightforward. Is that accurate? Any and all information will be greatly appreciated! Thanks in advance!
yes, there are a couple of companies in England that sell kits, however you do have to have a modicum of mechanical ability to install it - for example, you have to pull the head to add a spacer to the head gasket to lower the compression ratio. And you really need to have a dyno tune done to make sure it doesn't run lean.
Drea-min, does that carb stick out thru the hood?
veggievet - I would love to add a supercharger to my classic!
The only thing holding me back is cost.....
One suggestion, if you have the engine out, change the final drive ratio to either 3:1 or 2:76-1, the main thing you gain with a supercharger is torque, the taller gears will let you take advantage of that and the engine will be quieter on the road too.
With 2:76 gears and 10" wheels, my Clubby turns 3500 @ 75 mph - it's very comfortable on the highway......
Here are a few brands of kits I like.... http://www.vmaxscart.co.uk/mini-superchargers/
http://www.minispeed.co.uk/catalog/p...-supercharger/
http://www.jonspeedracing.co.uk/inde...e.php&cID=2130
No and no.
The overall rolling radius is about the same between 10 and 12" wheels because the tires on the 12's have a lower aspect ratio.
You do not have to remove the engine, tho you do have to remove the head to change the gasket and add the spacer.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
