Help!! Need a Canadian Mini Lower Raditator Hose!!
Old Jun 9, 2012 | 10:29 AM
TA2DMAC's Avatar
TA2DMAC
Is there a difference between the Canadian and UK version? I know are Radiators are different.
I just noticed the lower hose has a leak at top by the block. It's weather worn and cracking at the clamp.
Anyone know where I can find a new one?
Top hose was easy, matched it up to another at an Autoparts store. Don't think i'll be as lucky with the bottom.
Old Jun 9, 2012 | 11:09 AM
TA2DMAC's Avatar
TA2DMAC
After further inspection I found another tiny hose that connect from the engine block to the head on the back side near the Lower radiator hose mount at the top.
It's also leaking.
Old Jun 9, 2012 | 11:40 AM
TA2DMAC's Avatar
TA2DMAC
Figured it out, it's the waterpump bypass hose. Next question, Can I use a plug or do I need a new hose. I can get both
Old Jun 9, 2012 | 03:04 PM
Capt_bj's Avatar
Capt_bj
none of my parts catalogs show
'Canada' specific parts . . . .
Old Jun 9, 2012 | 03:07 PM
TA2DMAC's Avatar
TA2DMAC
I found it in my Haynes Manual. I found out the only hose that's really different is the upper hose because our cap is at the opposite end and the elbow faces forward. However I found one that matched that had to have an inch cut off at an Autoparts store for $4.00.
Old Jun 9, 2012 | 08:29 PM
LIL PIGG's Avatar
LIL PIGG
yes fix the tiny hose, you need it.
Old Jun 9, 2012 | 08:40 PM
TA2DMAC's Avatar
TA2DMAC
I'll be working on it tommorow. I also have the rear hose on order as well.
Pretty soon just about everything will be new.
jeremy_reyes94
Sep 6, 2019 07:53 AM
KrisMiss
Jan 3, 2016 02:02 PM
tr3y003
Oct 22, 2015 10:48 AM
OutMotoring
Aug 6, 2015 09:32 AM
