1971 Innocenti mk3 mini cooper??help please
Old Feb 16, 2012 | 07:40 PM
FDNYMEDIC's Avatar
FDNYMEDIC
does anyone know what does the toggle switch inbetween speedo and rpm does??? thanks again i just purchased and going to try to restore
Old Feb 18, 2012 | 10:46 AM
mk1leg's Avatar
mk1leg
that could be the dash clock light switch
Old Feb 18, 2012 | 08:52 PM
TA2DMAC's Avatar
TA2DMAC
Usually there should be a handbrake warning light there if it's a non-export model, otherwise the warning light is below the cigarette lighter and a plug or nothing at all should be where your toggle is. If there is a toggle, it's probably been added afterwards. Toggles were only used for a short time before they were changed to lever switches for saftey issues. (apparently they were afraid a toggle could impale you in an accident)
Old Feb 18, 2012 | 10:25 PM
FDNYMEDIC's Avatar
FDNYMEDIC
I've done searches on inno dashes I see the toggle switch on some dashes and not on others also its the same exact toggle I have on my mini .so I assume its a factory install just no one says what are switches for I want to also remove dash but I have no idea how to...I can't seem to figure it out...I cracked the plastic alil trying smh :(
Old Feb 21, 2012 | 02:39 PM
FDNYMEDIC's Avatar
FDNYMEDIC
[/IMG]
Old Feb 21, 2012 | 02:52 PM
FDNYMEDIC's Avatar
FDNYMEDIC
ok i posted a pic... I figured out that the bottom left toggel switch on the lower porsion of the dash is to turn on air vents....the button toggel switch directly on top with the sivel lines i have no idea what is that for...can someone help...in back of that toggle switch is four connector prongs...two on bottom right under toggle switch and two right above right behing amber light....now for the opposite side there is a small round red light which i dont know either what it is for...the light under cigeratte lighter please help if u can thanks again....im slowly restoring veh and will post pics of the progress
Old Feb 21, 2012 | 02:57 PM
mk1leg's Avatar
mk1leg
that's the heated rear screen on/off switch and the indicator on lamp above.....going by photo
Old Feb 21, 2012 | 03:01 PM
FDNYMEDIC's Avatar
FDNYMEDIC
ok second pic is of the dash im removing now...right inbetween rpm and speedo where u see an empty hole is a on/off simple toggle switch that looks exactly like the two below it...does anyone know what thats for..the two below left side turns on wipers and right side turns on outside exterior lights....i think it might be to simply to turn on and off dash lights since my dash lights dont go on.....even when headlights and exterior lights are ON or does it have a different purpose...all my guages work except water temp guage
Old Feb 21, 2012 | 03:10 PM
mk1leg's Avatar
mk1leg
as said above in my previous reply is usually a dash illumination switch...check if two wires are still behind 1 should be red with white tracer, and 1 solid red
Old Feb 21, 2012 | 03:18 PM
mk1leg's Avatar
mk1leg
have you got yourself a Haynes hand book this will have a wiring diagram in the back.......
Old Feb 21, 2012 | 03:54 PM
FDNYMEDIC's Avatar
FDNYMEDIC
I have the Hayes book but in wire diagram...it says nuthing on innocenti mini...only give for austins rovers morris etc.... I wish I could find one for inno thanks again....what about red light under cigarette lighter...any info on that
Old Feb 22, 2012 | 12:30 AM
Spank's Avatar
Spank
http://www.specialistminiforums.com/innolinks.htm
Old Feb 22, 2012 | 07:40 PM
TA2DMAC's Avatar
TA2DMAC
Are you talking about the rectangle orange light/switch combo? Thats the rear Windown defrost/heater with warning light to remind you when it's on.
The little red light is to remind you the handbrake is on.
Old Feb 22, 2012 | 07:44 PM
TA2DMAC's Avatar
TA2DMAC
By chance were driving lights/spot lights added to the front of the car? They may be to turn them on/off
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
