transmission
Old Aug 25, 2011 | 01:27 PM
minibilt's Avatar
minibilt
transmission
Hi, does anyone have an answer to this. I currently have a 1000 cc in my mini, I have an opportunity to buy a 1275 cc. Do I need to change the transmission to accommodate the motor, or can I use the one that is in there now. Cheers.
Old Aug 25, 2011 | 02:23 PM
Capt_bj's Avatar
Capt_bj
should be a direct bolt replacement
Old Aug 26, 2011 | 07:24 AM
Mini Mania's Avatar
If your current gearbox is a 'rod change' as used on all later models Minis, then is a direct bolt on. If you have a 3 synchro early box, it will not work. If you have a 4 synce box but has the 'remote' style gearshift housing, then is may or may not work. If you supply me the casting number from the front of the trans, I can probably tell you for sure!
Old Sep 4, 2011 | 03:49 PM
mk1leg's Avatar
mk1leg
Not all 1000cc G/boxes will accept a 1275cc block..............you would require a 1980 + to use both blocks (ie large Idler gear bearing) casing..........
Old Sep 4, 2011 | 07:11 PM
joltfreak's Avatar
joltfreak
Also what kind of 1275cc motor is it? A or A+
what did it come from? mini, metro, Austin America.....
Old Sep 5, 2011 | 03:13 PM
mk1leg's Avatar
mk1leg
this does not matter......an early 1000cc box uses a smaller idler bearing then the later box........and early boxes had thicker cast wall and will not to accept the rotation of a 1275 cc crank....
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
SJ-R50
Oct 28, 2015 08:39 AM
Oct 1, 2015 12:13 PM
B1mm3r101
Oct 1, 2015 06:22 AM
