engine id?
Old Aug 16, 2010 | 05:20 PM
k20mini's Avatar
k20mini
engine id?
ok i just wanted to see if anyone can give me info on my engine as i have no clue what or how big it is BHM1667
Old Aug 17, 2010 | 05:34 AM
kymummer's Avatar
kymummer
I went here .. http://www.minimania.com/web/SCatago...0/ArticleV.cfm
I see some engine numbers starting with BHM, but not the 1667 portion. Maybe the author of the MiniMania article could help ...
Old Aug 17, 2010 | 12:58 PM
Capt_bj's Avatar
Capt_bj
I'd try calling Seven .... 7ent.com
Old Aug 18, 2010 | 03:12 AM
czar's Avatar
czar
Your engine is a Gold seal factory reconditioned replacement, back in the days, we could order either a Silver or Gold seal reconditioned engine, from the dealers or from Unipart themselves, I have no further info for you regarding the engines CC, without further info from yourself, however I will be able to tell you more if you give me the crankshaft number which can be found between the journals, this should be just 1 digit difference from the engine No itself.
Also if your engine has no pressed steel plates at the rear of the engine covering the tappet and pushrod galleries, then it is most likely a 1275, this can be further identified by twin core plugs side by side at the flywheel end of the engine block, as all other mini engines had just 1 single core plug in this position.
I've had to dig out my very old mini books, and recall a lot of happy memories from my classic mini days, I hope I can assist you further.
Czar.
Old Aug 18, 2010 | 04:29 PM
k20mini's Avatar
k20mini
so my guess is that i can get the numbers off the crank unless the crank is out of the engine? could i just take a bunch of pictures of it would that help. and thanks so much for all the help
Old Aug 18, 2010 | 05:20 PM
czar's Avatar
czar
If you could post up photo's of the engine, front face, rear face, flywheel end, crank pulley end and the complete engine tag No, then I will do my best to identify your engine.
Old Aug 19, 2010 | 04:06 PM
k20mini's Avatar
k20mini
thanks alot i will try and get it done tonight or tomorrow
Old Oct 14, 2010 | 11:25 AM
H82WRK's Avatar
H82WRK
My 67 Mini had a Gold Seal motor in it, a 1380 CC, you don't happen to be the new owner do you?
Old Oct 14, 2010 | 11:33 AM
H82WRK's Avatar
H82WRK
Wow I just noticed that I need to change my sig.
If you are the new owner, my husband told me you had problems with the shifting. The trick that I found was to just to shift it slow and very deliberate, especially when going from 2nd to 3rd (have to shift to the middle then wave to the left). Downshifting from 4th to 3rd can also be tricky. It took me awhile to get used to it but when I started shifting it like it was an old car and not a newer stick, things improved dramatically. I just wanted to let you know in case you were considering replacing or fixing the tranny. Joe my husband also had a hell of a time shifting the beast. It's like it is notchy and once you find the pattern it's really easy to make her behave. Maybe it's just a lady's touch. If you are the new owner, I hope you are enjoying her, that is a great Mini. Oh PLEASE don't trash that tranny either if you decide you have no choice but to rebuild, it is a 68 Cooper S tranny. Same with the seats and the brakes, those are all out of the same 68 Cooper S.
Old Oct 25, 2010 | 03:06 PM
mk1leg's Avatar
mk1leg
Put up some pics of top frpnt and rear of engine and I can what you have........
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
