need help locating
Old Oct 15, 2008 | 09:23 AM
logank68's Avatar
logank68
need help locating
just got a 70 mini and can't find the correct ign. switch and leads would be greatly appreciated
Old Oct 15, 2008 | 10:28 PM
AuthiMini's Avatar
AuthiMini
I'd check with Heritage Garage or Minimania. If that doesn't work, put up a message on the Minimania board, but describe in detail your car: Year, model, where made, etc. In 1970, there were lots of different models of Mini, made in lots of different countries. All with differences. My 1973 Innocenti Mini has an ignition switch that could not be replaced without buying the whole column lock and switch system - $$$$!. I repaired it myself, but it wasn't a trivial task.
Old Oct 16, 2008 | 12:21 AM
Mercy's Avatar
Mercy
Can you take a picture of your column? I might have one but not sure.
Old Oct 16, 2008 | 04:45 AM
stratman977's Avatar
stratman977
https://www.northamericanmotoring.co...gnition+switch
You may be in the same boat as this guy.
Old Oct 16, 2008 | 08:18 AM
jeffm5150's Avatar
jeffm5150
I have a 1973 that had a very worn ignition switch. Since the switch is no longer available, I located a switch from a 1973 MG and ported the internals over. A bit of work but the end result was worth the effort. I found the ignition switch from AutoHausAZ.
Please post if you find a source for replacement switches.
Jeff
Old Oct 16, 2008 | 09:04 AM
elprofe's Avatar
elprofe
avoid the headache and install an English one.
Old Oct 16, 2008 | 07:10 PM
jeffm5150's Avatar
jeffm5150
Please elaborate.
Old Oct 17, 2008 | 05:31 AM
Madoc's Avatar
Madoc
I got my '73's ignition switch assembly from Heritage. Very happy with the transaction.
Old Oct 18, 2008 | 12:39 PM
jeffm5150's Avatar
jeffm5150
Please elaborate on what "install an English one" means
imncrxtc
Jan 19, 2018 03:16 PM
NorthWestEuro
Oct 22, 2016 07:57 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
vbmike
Oct 15, 2015 04:32 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
