Braided brake lines
Old Feb 19, 2008 | 03:10 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Braided brake lines
While I was buying parts for my Mini from England, I threw a set of braided brake lines into the shopping cart. Time to finally install them yesterday. What a pain in the neck, even with a hoist!
The 2 front lines have different connections from each other, and the 2 rear lines, while the same as each other, are different to either of the fronts.
Front passenger side (my car is RHD), there is a 24mm locking nut that holds the line in place against the subframe. This must be completely removed and slid up the hardline to expose the 11mm nut that seals the lines together. This is all done through a rectangular access hole, maybe 1 1/2 inches high by 3 wide.
The drivers side, uses a banjo bolt connection. The access hole is covered by a large steel plate that I had to bend out of the way. I removed the banjo bolt, then had to work on the 24mm retaining nut. What a pain in the proverbials! There was no way I could have done it without a 24mm socket and a 90 degree bending ratchet.
The rears weren't such a pain but were impossible to access with the wheels on.
Anyway, after about 4 hours, my Mini has nice braided brake lines. I decided to wait on the clutch line coz it was almost dinner time.
Old Feb 19, 2008 | 03:53 PM
Minimad's Avatar
Minimad
My solution to these problems...two words....
FLIP FRONT!
Old Feb 20, 2008 | 06:09 PM
Rocan's Avatar
Rocan
hows it look? performance? pictures?!?
Old Feb 20, 2008 | 06:46 PM
NoModMini's Avatar
NoModMini
...now you know the reason for my screen name
Old Feb 20, 2008 | 09:35 PM
Agro's Avatar
Agro
Looks good, performance it shouldn't make a lot of difference since I'm not pushing the car hard enough to get brake fade. It will prevent any possible rubber dessication issues with the Vegas anti-humidity though.
Old Feb 21, 2008 | 09:55 AM
Rocan's Avatar
Rocan
sounds cool, i think that overall this was a good mod seeing as how it will last for a longer time then stock.
Old Feb 23, 2008 | 08:14 PM
dr dave's Avatar
dr dave
Make sure they aren't too long, and rub against the front caster rods. If so, they will fray. You can wrap them with the special plastic wrap availible at your local speed shop.
dr dave
Old Feb 23, 2008 | 08:17 PM
Agro's Avatar
Agro
I ordered them from MINISpares in the UK, so they should be the right part/length. Came with a clutch hose too, but that's not installed yet.
Old Feb 24, 2008 | 08:50 AM
dimini's Avatar
dimini
Agro-Had you employed one of those leggy models as an assistant, I'd bet you would have gone all the way and installed the clutch cable, too. (I would have!)
Nomodmini-You've owned each of the cars in your sig? That's prolific. It would be hard for me to let go of a 55 speedster, 930 and 914/6. Wait a minute, the second I noticed a puff of smoke from the 930--I'd let go really fast.
Old Feb 24, 2008 | 11:41 AM
Rocan's Avatar
Rocan
I agree with you on that one!
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
