Front end alignment?
Old Sep 10, 2007 | 07:10 PM
Angel Face's Avatar
Angel Face
Well, I have finally finished the engine swap on my 1990 Mini. The engine runs beautifully with its new carb, and the brand new clutch grips wonderfully. I took the Mini to have its front end aligned, and the shop was unable to align it to specs because their equipment requires the toe settings to be measured in degrees, not "mm out" or "mm in".
The specs for my Mini read:
Front: 1.58mm toe-out.
Rear: 3.17mm toe-in.
What is the equivalency for the front axle when expressed in degrees? Thanks!
Old Sep 10, 2007 | 09:24 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
1.58 mm = about 0.0625 degrees or 1/16 inch
So
Front: 1/16" toe out or +0.0625 degrees
Rear: 1/8" toe in or -0.125 degrees
These settings look OK.
woodstudio
Mar 15, 2020 08:28 AM
ebowling
90
Aug 4, 2019 09:15 AM
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
damncajun
Aug 17, 2015 08:25 PM
