Compression Test
Old Sep 10, 2007 | 07:40 PM
BRGPA's Avatar
BRGPA
Compression Test
I have a 1275 to install in a classic Mini. It's sitting beside the car, and last week a compression test showed almost non existent compression in three cylinders and only 25psi in the fourth. The engine was turned with a socket at the clutch end and a bit of WD 40 was squirted in the spark plug holes before spinning. Is WD 40 OK or should something heavier have been used? In any event, the head was pulled and the valves will be checked out this week. The head gasket seemed OK, but we'll get a better look at it, too. Thoughts? Thanks!
Old Sep 10, 2007 | 07:45 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by BRGPA
I have a 1275 to install in a classic Mini. ...The engine was turned with a socket at the clutch end and a bit of WD 40 was squirted in the spark plug holes before spinning....Thoughts? Thanks!
I can't imagine that you can get a compression reading by spinning the crank with a socket. You'd have to get the pistons to move much faster like it would with the starter motor.
A leak-down test, OTOH, is fine to do on the bench.
Rich
Old Sep 11, 2007 | 04:10 AM
Minimad's Avatar
Minimad
Jump the starter with a set of jumper cables and spin it up on the floor. Open the throttle WOT when doing it. I've actually run them on the floor....
Fordgt4
Oct 10, 2015 10:42 AM
jennster
Sep 28, 2015 06:19 PM
silence2-38554
Sep 28, 2015 12:19 PM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
