Alabama Motoring Society: BAMA and Rocket City The forum for the Alabama Motoring Society.
Visit the BAMA club site at www.bamamini.com
Visit the Rocket City MINI club site at www.rocketcitymini.com
Pulley
Old Sep 13, 2006 | 12:36 PM
mozzarella's Avatar
mozzarella
Pulley
I sold my MCC and got an S, I see lots of people charging the supercharger pulley, three questions what size, where to get it and who around here could put it on?
roach
Old Sep 13, 2006 | 05:33 PM
magic mini's Avatar
magic mini
15% PULLEY IS SAFE. YOU CAN GET IT FROM ALOT OF PLACES BUT I GOT MINE HERE. http://www.jscspeed.com/mini/mini_ba.../mini/mini.htm
GOTO STEPHEN'S GARAGE TO HAVE IT PUT ON. HE DID MY 15% PULLEY AND MY 2% CRANK PULLEY. (2% CRANK PULLEY IS ALMOST NOT SAFE ).
Stephen's Garage
Independent BMW/Mini Cooper Specialist
Stephen Wittkop
2417 1st Avenue South
Birmingham Alabama 35233
205 326 4542
Old Sep 13, 2006 | 05:38 PM
SB's Avatar
SB
Actually the 2% crank pulley allows the ac and other components to run more close to stock. Making them operate at what can be considered a safer speed. Though it's all about how you feel about removing the harmonic balancer from the car. It's said the MINI doesn't require one yet there are always arguments that its best to have.
I had a 2% crank pulley on my last MCS and would like one on this one except it will bump me out of STX class in autocross. I've thought about the 0% pulley since it is lighter but I don't feel the benefit of it is worth over $200.
Anyway. Like Magic said. Stephens garage will take care of you.
Old Sep 13, 2006 | 09:07 PM
Yucca Patrol's Avatar
Yucca Patrol
Once you go with a combo beyond 15%, you run into some long term problems. The 2% crank pulley does decrease wear and tear on the ac, but the added 2% can also cause premature wear of the supercharger.
Definitely go to Stephen.
Congrats on the new S!
Also, you will want to change to colder spark plugs and probably re-map the ecu to best take advantage of the increased boost.
Old Sep 14, 2006 | 07:54 AM
mozzarella's Avatar
mozzarella
Talked to Stephen this morning and when I hit about 1500 miles he if going to change the oil and put on the 15% pulley so should be in a couple of weeks
Old Sep 14, 2006 | 08:53 AM
DrkSilvrMini's Avatar
DrkSilvrMini
16% pully from M7
had it on mine and loved it
Old Sep 14, 2006 | 09:58 AM
bzn by's Avatar
bzn by
How much does Stephen's garage get for a oil change?
Old Sep 14, 2006 | 10:18 AM
mozzarella's Avatar
mozzarella
I think about $60 didn't ask this time. He said he would put on a UUM pulley? Anybody have one.
Old Sep 14, 2006 | 10:57 AM
bzn by's Avatar
bzn by
Thanks, I know where we will be going.
Old Sep 15, 2006 | 05:25 AM
Yucca Patrol
Stephen has VERY good Royal Purple synthetic oil available for our MINI's too.
Old Sep 15, 2006 | 05:55 AM
mozzarella's Avatar
mozzarella
That is what he is going to put in mine when he changes it and puts the pulley on end of next week.
Old Sep 21, 2006 | 07:38 AM
mozzarella's Avatar
mozzarella
Pulley has not come in ordered an Alta cold air intake maybe if the pulley does not come in today I'll get Stephen to put it on if not it, might be mechanics for nitwits one o one.
Old Sep 21, 2006 | 11:12 AM
Yucca Patrol
roach: the intake is rather easy to install yourself with only a couple of hand tools and 4 letter words. It is especially easy if you did not order the silicone hose because attaching the lower portion of the hose was the only bothersome part for me.
Old Sep 21, 2006 | 11:47 AM
mozzarella's Avatar
mozzarella
Pulley has not come in yet so I'm just going to let Stephen do it. I might be the worst mecanic (even worse at that than spelling) in the state. Thank god I don't like doing it.
What do I do next?
Old Sep 27, 2006 | 01:05 PM
mozzarella's Avatar
mozzarella
Got the pulley put on and the oil changed. Stephen did not put the Alta CAI on said the silicon tube was much to big where it mates to the engine and there metal part did not meet up to the stock Mini box part that is left in so did not put that on. He also said that the CAI would not really do anything. Hoping Detroit Tuned will take it back.
Old Sep 27, 2006 | 01:23 PM
pjschaffer's Avatar
pjschaffer
Changing the diameter of the SC pulley will only change the speed of the SC and anything on the same shaft as the SC at a given RPM. The drive belt is driven by the crank pulley so unless you change the crank pulley, the belt speed remains the same thus the AC speed stays the same as it is not on the SC shaft. The water pump is on the SC shaft. Randy Webb has discussed that this is one of the reasons he prefers the 15% pulley. With more reduction, the water pump spins faster at a given RPM than stock. This can cause the pump to cavitate (reduced flow) at high RPMs typically found on the track. Randy explains it much better here.
Phil
Old Sep 27, 2006 | 02:58 PM
mozzarella's Avatar
mozzarella
Ok talked to Detroit Tuned they say it will fit, now since I'm a mechanical nitwit who else in town can put this on?
Old Sep 27, 2006 | 03:36 PM
shorn's Avatar
shorn
Stephen said that a CAI really didnt do anything?? That's contrary to a lot of reading and certainly a lot of urban legend. Maybe he means that in ordinary driving you won't notice a difference. Read up on recommended mods in MC(squared).
Old Sep 27, 2006 | 05:23 PM
ScottRiqui's Avatar
ScottRiqui
How exactly does this work? A 2% oversized crankshaft pulley will make the A/C compressor, supercharger and alternator spin *faster* than stock, not "more close to stock".
Or did you mean that a 2% crank pulley will turn the accessories "more close to stock", when compared to a 3% or 4% pulley?
Scott
Old Sep 28, 2006 | 06:09 AM
bzn by's Avatar
bzn by
We had the helix CAI installed at the dragon and we can tell a difference, not a huge difference by no means, but we can tell a difference.
Old Sep 28, 2006 | 09:58 AM
mozzarella's Avatar
mozzarella
Talked to Alta this morning very helpful and Munich Sport will put it on Monday morning.
Old Sep 28, 2006 | 12:37 PM
sjolly's Avatar
sjolly
SB and I put the Alta CAI on my MCS. We had to work with the tubing a bit but we got it on and works great, I like the sound of the air rushing in.
Old Oct 2, 2006 | 08:13 AM
mozzarella's Avatar
mozzarella
Munich - Sport put the Alta CAI on this morning with no problem. A silly question why is the whinning so much louder?
Old Oct 2, 2006 | 08:29 AM
bzn by's Avatar
bzn by
We noticed that right away also, it about drove my husband crazy at first:impatient .
Did Paul do the install for you?
Old Oct 2, 2006 | 08:36 AM
mozzarella's Avatar
mozzarella
Yea if he is the grey haired guy, going to have a rear sway bar put on next, they seem very good.
