4th Generation MINIs Discuss the new EV Hardtop and ICE Hardtop models here.
ICE Oil Change
Old Aug 3, 2025 | 06:18 AM
maryakg's Avatar
maryakg
Oil Change
Finally had a chance to put my 25 up on ramps.
has anyone changed oil yet on their own? It looks almost impossible with the protective shield at bottom of engine compartment.
Old Aug 6, 2025 | 06:16 AM
Here is the F56 2014-2019 version which should be similar. The 2025+ F66 and F65/F67 share the same oil filter as the 2014-2019 models.
https://www.northamericanmotoring.co...rocedures.html
https://www.ecstuning.com/Mini-2025-...e/Oil_Service/
The underhood shield aka the belly pan. Looks like it has the same access ports. https://www.realoem.com/bmw/enUS/sho...diagId=51_C850
https://www.ecstuning.com/Search/Sit...h/51755A2EB59/
Old Aug 17, 2025 | 05:28 PM
Blu_lite's Avatar
Blu_lite
The f66 has the same oil drain and oil filter flaps as f56 gen. You don't need to remove the whole shield.
Old Aug 18, 2025 | 04:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Removing the shield will give better access to the oil filter, and make less mess. With a screw gun, adds maybe 5 minutes to the job.
Old Sep 1, 2025 | 10:02 AM
Mforce's Avatar
Mforce
So on F56, how does one know or really sure if the car has engine oil?
I know there's no dipstick.
Let's say the engine has almost no oil ( let say you don't know ), do you have to run the engine in order to see the oil level on the dash? if that's the case you are doing more damage to the engine.?
Old Sep 2, 2025 | 10:40 AM
I think it should throw a warning light if its below a certain amount? Thats what the BMW do with that sensor. Never seen someone test it yet.
Old Sep 3, 2025 | 06:20 PM
elkay's Avatar
elkay
Any reason you're not taking advantage of the included free dealership oil changes?
Yoshimura 1
Mar 11, 2024 06:40 AM
Buckey
F54 :: Clubman Talk (2015+)
Apr 18, 2018 08:32 PM
S1monLM
Aug 9, 2011 06:46 AM
niquemarshall
Aug 4, 2011 03:15 PM
