4th Generation MINIs Discuss the new EV Hardtop and ICE Hardtop models here.
ICE Side Window Shades
Old Jun 6, 2025 | 04:15 AM
SpectreGadget's Avatar
SpectreGadget
Question Side Window Shades
Hi all,
Just picked up my first Mini, a '25 Cooper S 2-door. Since the fold down window shades are so small and don't do much on the driver's side to block sun, what do y'all do? Is there an aftermarket options that work well, or just rely on window tint?
Old Jun 23, 2025 | 11:32 AM
DesiFit44Paceman's Avatar
DesiFit44Paceman
Cool
Good question, since MINI should have kept the previous flip down shade. I'll be following this.
Old Jun 23, 2025 | 01:45 PM
Wonder if the old F56 ones would work? They do share a bunch of stuff on the F66.
https://www.northamericanmotoring.co...ide-visor.html
Old Jun 23, 2025 | 02:44 PM
SpectreGadget
Thank you, I'll take a look. Now to figure out how to get some measurements on the openings!
Old Jun 23, 2025 | 06:07 PM
SpectreGadget
Looks like ECS has the part too? https://www.ecstuning.com/b-genuine-...i/51167376859/ How is your return policy if it doesn't fit?
Old Jun 24, 2025 | 07:40 AM
Hello,
Just call in or process a return through your account if it does not fit. I would measure screw to screw first and go from their, i can pull that one side and measure it.
Mike
Old Jun 24, 2025 | 04:18 PM
SpectreGadget
Hello,
Mike
The left clip defeated me without better trim tools (or skill) so the best measurement I could get for now is from opening to opening of the clip in lock, which is ~ 148-149mm. I'll try to get it all the way out for a better measurement, and hopefully a part number visible.
Old Jun 25, 2025 | 08:19 AM
I got 149mm from screw center to screw center.
Hope hat helps
Old Jun 25, 2025 | 07:05 PM
SpectreGadget
Hope hat helps
Thanks! I placed an order, so I'll report back when it arrives and try it out.
Old Jun 26, 2025 | 06:50 AM
Awesome!
Old Jul 3, 2025 | 08:29 PM
SpectreGadget
So close.... the clips line up, but the hinge supports don't fit within the recess that holds the grab handle...
Old Jul 8, 2025 | 07:48 AM
Dang, i guess you could trim the side of the clip part or trim out that hole?
Old Jul 8, 2025 | 07:52 PM
SpectreGadget
The outside of the clips, where the hinges are stop the handle from going deep enough in the recess of the metal body to clip in. The hinges need to be on the inside of the clip to work or they need to be moved 'above' the clip to give the clearance necessary.
Old Jul 9, 2025 | 06:32 AM
Ok thanks for trying. So close.
chappy8599
Apr 9, 2013 08:14 AM
OutMotoring
Feb 22, 2005 08:37 PM
LizzyBobio
12
May 18, 2003 07:43 AM
