4th Generation MINIs Discuss the new EV Hardtop and ICE Hardtop models here.
ICE USB Ports on '25 Coopers / F66
Old Dec 2, 2024 | 01:00 PM
ids's Avatar
ids
Hi
I'm from the UK so we get slightly different spec to you in the US, however can any of you help.
  • Do your cars come with two USB C sockets just in front of the arm rest ? (Assuming yes !)
  • Are they charge only or are they both ? (In the UK they have charge only C sockets.)
  • Don't suppose any of you have pulled that trim out and seen where the round connector on the USB ports is routed to ? (I don't have access to wiring diagrams)
Mini are being unhelpful, as well as not having any options related to this when you buy the car.
The bluetooth options are pretty dire, with no control of music playing at all from the OS9 media player other than forward/back.
Are they really trying to force everyone down the Android Auto/Carplay route ?
Thanks for any help anyone can give
Old Dec 3, 2024 | 05:56 AM
chrunck's Avatar
chrunck
Both what? I'm not sure what you're trying to accomplish.
Old Dec 3, 2024 | 11:48 AM
ids's Avatar
ids
Sorry was late.
Are yours in the USA both charge and data. So can you put a USB stick into the car, it reads it and can then play files from it ?
Old Dec 5, 2024 | 12:29 PM
elkay's Avatar
elkay
I have only tried my phone for wired Android auto and the ports appear to be charge-only from that regard.
Old Dec 6, 2024 | 02:52 PM
Kerosene's Avatar
Kerosene
Sorry was late.
My car is a USA car.
Both USB can be used to read data and charge. Verified. I had two different USB thumb drives in both slots at the same time.
Old Dec 10, 2024 | 10:59 AM
ids's Avatar
ids
Hey thanks for the reply. We still are trying to find out why the Muppets at BMW/Mini have not fitted them in our car, even though it's a high spec one in the UK
My next step is hoping someone has access to the wiring diagrams as you would think it's a simple cable missing !
Old Dec 29, 2024 | 08:07 AM
ids's Avatar
ids
So for anyone looking, confirmed the part number for the USB ports is 84 10 5A57B32 and the Fakra HSD Cable that connects to to the Head Unit is 61 11 5B35C45
When connected, supprise supprise the car now has USB media connectivity. Artists, Genre, Albums and album art all work. Amazing.
Old Dec 30, 2024 | 09:40 AM
Looks like people do the same thing in the i4 bmw, charging and usb function, hence the icons/.
https://www.ecstuning.com/b-genuine-...105a57b32~oem/
and https://www.ecstuning.com/Search/Sit...h/61115B35C45/
2 x USB-C in armrest mod | BMW i4 Forum
Original BMW 2 U06 X1 U11 U12 USB Anschluss Dual 5A57B32 | eBay
Old Mar 20, 2025 | 04:29 AM
Septercius's Avatar
Septercius
I'm interested in making this change to my 07/24 Cooper S, which also just has power-only USB ports. I find the Bluetooth interface very difficult to use.
I've had a quote from my local dealer for the replacement USB ports and the cable, which is around £108.
What exactly is involved in doing this? Presumably I need to take the centre console to bits to swap the module over, and somehow get to the back of the screen unit to plug the cable in. Is it an additional cable to what's already there, or do I need to swap them over?
Old Mar 21, 2025 | 12:08 PM
ids's Avatar
ids
I'd snap their hand off for £108. The parts and labour alone will cost that much. That sounds cheap.
A dual port USB/Power module pop up for around £30-40 on ebay used, and the Fakra HSD cables are about £20-30 due to the length and rarity. Add in some looming tape, cable ties and plasters for the cuts you will get
There is also quite a lot to remove....
  • Glovebox
  • Release the IHU module and cables behind the glovebox
  • Transmission tunnel covers
  • Wireless charger
  • Stupid sandwich box
  • Centre Console
Then running the cable into the IHU and strap it in. Replace the module in the centre console and plug in power and data cable.
Depends how you are. Its a lot of faffing for just £108.
Good luck
Old May 11, 2025 | 10:16 AM
Alan292's Avatar
Alan292
Just for reference, the 2 usb c ports on my 2025 JCW only put out 13 watts each, not enough to max out modern phone charging speeds
Old May 11, 2025 | 12:33 PM
ids's Avatar
ids
Sounds about right. The wireless charger isnt that great either as the positioning of the phone is critical and how long is the elastic going to last ? When I had it out its basically just melted/fused on so not replaceable in the future.
They really have done a half arsed job. For a so-called premium brand some of the things they have done is shocking.
Old May 11, 2025 | 10:55 PM
Alan292's Avatar
Alan292
yeah its not the best for sure. i have a 30w car charger coming and i intend to hook up two 15w magsafe pucks to it and mount it over the useless wireless charger. will post results if i can get it halfway decent.
NBCGLX
Navigation and Audio
Jul 22, 2018 04:37 PM
Shoe Coupe
Electrical
12
Jul 26, 2013 10:11 AM
Subzero
Jul 1, 2011 12:19 PM
cozyp828
Sep 28, 2010 06:44 PM
zanary
R57 :: Cabrio Talk (2009+)
25
Jun 5, 2009 03:37 PM
