3rd Gen FAQs 3rd Gen Common Questions & Answers!
How to replace battery in key FOB
Old Nov 27, 2017 | 08:57 AM
vetsvette's Avatar
vetsvette
Moderator
Check pages 34 and 35.
http://www.miniusa.com/content/dam/m...rd_Monitor.pdf
Old Jan 16, 2019 | 04:05 PM
Sansho's Avatar
Sansho
Having just done this, recommend not using your key to open things up, as Mini directions provide, as you may chew up the plastic. Use a flat head screwdriver that fits.
Old Jan 1, 2020 | 12:23 PM
ptkacik's Avatar
ptkacik
Always use a new battery.
My key died and the battery read 2.89 volts. I found one in a drawer that read 3.02 volts but it still did not work. I then bought a new battery at the store (that read 3.28 volts) and now the key works just fine.
regards,
Peter
Old Jan 1, 2020 | 04:20 PM
sgscomps's Avatar
sgscomps
Like it was mentioned above, follow the instructions in the manual and use a small flat head screwdriver. I replace more batteries in BMW remotes than MINI remotes all day in a dealer parts department. I would rather replace BMW ones before these any day. These are the hardest remotes to replace batteries in. If you worried and your MINI dealer is close by take it to them and have them replace it. The battery s less than $10.00. You should only have to replace it every 2 years.
bimpower
Aug 31, 2012 02:28 PM
kublai68
May 23, 2011 04:11 AM
shane1600
Jun 24, 2010 01:55 AM
TheBigNewt
Apr 29, 2007 12:57 AM
jebernauer
Dec 14, 2005 05:23 PM
