2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
R56 Don't know what its nomenclature is
Old Mar 16, 2026 | 02:33 PM
HUCKLEBURY66's Avatar
HUCKLEBURY66
2017 countryman awd s how to reset oil change warning?
Old Mar 17, 2026 | 12:50 PM
PClay's Avatar
PClay
No Guarantees but try this:
F56 Mini Service Check Reset Instructions
Resetting indicator alerts for Routine Service Check, Oil Change, and Brakes is super easy for the F56 and F56S.
1) Car should be OFF.
2) With foot OFF of the brake, press the START button once to power up the car but not start the engine.
3) Locate the Trip Odometer Reset button on the speedo, at about the 5 o'clock position.
4) Press and HOLD the Trip Odometer Reset button.
- You will see a message: "! Ignition turned on!" Keep holding the button.
- You will see the "car raised on lift" symbol, and it may or may not say, "RESET Possible". Release the button.
5) You are now in alert reset mode. You can toggle between the three reset options: service, oil, and brakes by giving one quick press to the Trip Odometer Reset button. Stop on the one you wish to reset. If a reset is permitted for the particular option, it will say "RESET Possible".
6) To reset the alert, press and HOLD the Trip Odometer Reset button until you see the message, "Reset?" then release the button.
7) Press and HOLD the Trip Odometer button again. A message will say, "System Resetting" and a progress bar will display. A message will now say, "System Reset". Release the button.
8) To get out of the alert reset menu, just wait several seconds or turn the car back off by again pressing START without the brake applied.
Andy K
Jun 12, 2021 02:57 PM
igoeco2001
Dec 17, 2016 06:37 AM
TC Mini
Jul 15, 2016 05:14 PM
ZK-JCW
Sep 19, 2014 07:05 PM
Bugs
Aug 22, 2005 07:08 AM
