2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Reset service indicator help
Old Sep 11, 2019 | 05:52 PM
oldspeedr's Avatar
oldspeedr
Reset service indicator help - SOLVED
SOLVED
It does work just as the 2018. I obviously wasn't doing something correctly when I tried before.
Just purchased a pre-owned 2019 Countryman. I would like to reset the oil indicator as I've taken care of that task. I've been online and on youtube and found reset procedure for a 2018 and older minis The process was: enter vehicle, close doors, press start switch without touching the brake. Press and hold the odometer reset button until the service items appear, press again to scroll, press again to reset. I've tried that and it doesn't work.
Am I doing something incorrectly or is there a different protocol for the 2019?
Old Sep 15, 2019 | 09:03 PM
MrToyMan's Avatar
MrToyMan
Originally Posted by oldspeedr
SOLVED
I just did a Oil change today and have to reset the oil service indicator .
Hope this works for you. Go to the almost end ( 20:05 ) of the video and there’s a portion about resetting the service indicator.
It really worked for me when the engine is running.
if it doesn’t work. I can send you the instruction from Mini
Old Sep 22, 2019 | 05:36 AM
Blu_lite's Avatar
Blu_lite
This not for oil change but still service indicator topic for future readers
I changed my brake pad and sensor (aftermarket). Went to reset service system said unsuccessful.
Remove sensor from reader clip behind wheel well plastic. Jumpered with wire. Reset service successfully. Re attached sensor.
newbaycolony
Mar 17, 2019 08:58 AM
radaghast
Aug 11, 2017 07:46 PM
cdboss
Mar 29, 2014 12:06 PM
PatL
May 25, 2011 03:28 PM
dubsdj
Sep 9, 2007 04:06 PM
