2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 No keyless entry on Signature Trim?
Old Aug 1, 2018 | 12:31 AM
mountainsean's Avatar
mountainsean
Question No keyless entry on Signature Trim?
I took delivery today of a 2019 Signature Trim Countryman SE. According to Mini's website and the dealer's website, the car should have "Comfort Access" keyless entry standard:
https://www.miniusa.com/model/hybrid...ountryman.html
It says: "COMFORT ACCESS - STANDARD - Leave the keys in your pocket with our keyless entry feature. Comfort Access adds a transceiver to your key that your MINI will recognize, letting you lock or unlock the car by pushing a button on the door handle"
My car does not have this feature. There is no little black button on the driver's door handle to push to lock/unlock. How is that possible? Did I get some sort of odd build? This is a huge feature for me, I can't believe i didn't notice it before leaving the dealership with the car. Does anyone else have a 2019 Countryman SE without keyless entry?
Thanks,
Sean
Old Aug 1, 2018 | 01:03 AM
18cmjcw's Avatar
18cmjcw
To verify the build, I would go to http://bimmer.work and input the last 7 of your VIN. This will report back to you everything that was built into your car at the factory, including Standard Equipment and Options. Comfort Access System should be code 322 (at least it was on my 2018 JCW, and I believe these codes do not change for different cars). If it's in the build specifications and not on your car, or if it's not in the build specs and the car was actually ordered as a Signature Trim by the dealer, this will at least give you a starting point for the "Huh? WTF?" discussion you will undoubtedly be having with the dealer.
-Bob
Old Aug 1, 2018 | 05:54 AM
mountainsean
When I enter my VIN, and hit submit, all I get is an error that "something went wrong, please try again."
Old Aug 1, 2018 | 07:27 AM
JasonMa's Avatar
JasonMa
I took delivery of a 2019 MCS on Friday with signature trim and I've been using the keyless entry since then. Sounds like something was mis-built unless the Countryman has different signature trim options than the 2-door hardtop.
Old Aug 1, 2018 | 07:58 AM
18cmjcw's Avatar
18cmjcw
That's strange.... I checked it again last night with the last 7 of my own and it worked.
Here's another site you can try: https://bmwvin.com . I just tried it a minute ago with my own VIN and it worked. I think it works with either the last 7 or the complete 17 VIN. This site shows the Comfort Access code as S322A. I've uploaded a screenshot from this site showing the code.
-Bob
Attached Thumbnails No keyless entry on Signature Trim?-comfortaccessspec.jpeg
Old Aug 1, 2018 | 09:27 AM
mountainsean
Thanks Bob. That second site worked. Code 322 is not listed in the build, which makes no sense to me. It's clearly listed as a standard feature on the MiniUSA site, as well as the description the dealer had on its website. I've got a call into the dealer to see what's up. I'm hoping is as simple a fix as swapping out the door handles with the ones with the buttons, and not a whole rewire. Keyless start/ignition works, so maybe it's already wired for keyless entry.
-Sean
Old Aug 1, 2018 | 10:06 AM
BossHoss's Avatar
BossHoss
On your Window Sticker under Iconic trim does it list Comfort Access keyless entry?
Old Aug 1, 2018 | 10:12 AM
mountainsean
I have the Signature Trim. But it’s still listed as standard for all trims on MiniUSA.
Old Aug 1, 2018 | 10:15 AM
BossHoss's Avatar
BossHoss
(Oops...I meant Signature trim....) Signature trim listed on the LET'S MOTOR Window Sticker?
Old Aug 1, 2018 | 11:48 AM
18cmjcw's Avatar
18cmjcw
I hadn't thought of checking the sticker -- good idea. "Comfort Access keyless entry" is shown as "Included" on my sticker.
Old Aug 1, 2018 | 11:59 AM
mountainsean
I don’t have the window sticker handy - but it was listed as signature trim on the dealer’s website.
Old Aug 1, 2018 | 12:17 PM
mountainsean
...and it has to be signature trim - you can’t even build up he classic trim with my options, like the tech package.
Old Aug 1, 2018 | 12:25 PM
BossHoss's Avatar
BossHoss
You might want to confirm your VIN Number against the VIN Number on the Window Sticker--just to be sure.
Let us know what happens.
Old Aug 16, 2018 | 10:56 PM
mountainsean
Circling back on this thread to provide an update/conclusion: after talking it through with my dealer (Schomp in Denver), they agreed to let me return the vehicle for a credit with them, which I used to purchase an Iconic trim SE, paying the difference between the two vehicles. They honored the same discount I'd received on the original purchase, so basically I was only out the $1k or so additional cost for the Iconic trim. The keyless entry works great, and I'm digging the kick-to-open tailgate and the HUD too. So, a good ending. Just beware Signature trim buyers: not all SE's have comfort access standard, despite what the website says.
Old Aug 17, 2018 | 07:28 AM
JasonMa's Avatar
JasonMa
I'm glad your happy but considering you said the sticker had it listed and the website has it listed, I'd be pretty pissed to find out it still wasn't included in my original build. Seems like they managed to bait and switch you into a better model.
BTW, my recent purchase was from Mini of Loveland so we must be in the same general area (I'm in Arvada).
Old Aug 17, 2018 | 07:59 AM
mountainsean
No bait and switch... I'd wanted the Iconic all along, but they couldn't find one with the color scheme I wanted, so I gave up waiting and compromised with a Signature Trim. After the keyless mess, they were able to find a suitable Iconic from another dealer and had it shipped. I'm satisfied with how it worked out in the end, though I'm still a bit miffed that MiniUSA advertised comfort access as standard.
-Sean
Old Aug 17, 2018 | 12:58 PM
Nathan Lines's Avatar
Nathan Lines
Same issue.... the signature package shows comfort access on the website but my car wasn't built with it, and on the navigation package it shows wireless charger which also mine was missing....Dealer went to bat, Mini admitted packages changed a bit between production and what website listed, as the signature package code is different then what it is now. Very happy with the outcome as the cash incentive to keep the car outweighed the two options....
Old Aug 17, 2018 | 01:01 PM
JasonMa's Avatar
JasonMa
Interesting, when did you guys order your cars? I placed my order on June 5th for a F56 S with signature trim and got the listed keyless entry and wireless charger with the nav package. I didn't care about the charger (my phone is too old to support it, but when I upgrade it will be nice I guess) and didn't really care about the keyless entry until I got it 7 weeks later. Now I love that feature.
As of today those options are still listed on the builder on miniusa.com. I'm just surprised that they are continuing to sell themt aht way if they don't come that way.
Old Aug 17, 2018 | 01:24 PM
Nathan Lines
Originally Posted by JasonMa
Interesting, when did you guys order your cars? I placed my order on June 5th for a F56 S with signature trim and got the listed keyless entry and wireless charger. I didn't care about the charger (my phone is too old to support it, but when I upgrade it will be nice I guess) and didn't really care about the keyless entry until I got it 7 weeks later. Now I love that feature.
I assume this only applies to F60 SE PHEV, that is what Mini is saying had changes on between production and website builds
Old Aug 17, 2018 | 01:27 PM
JasonMa's Avatar
JasonMa
You're probably right. But the build for that model still lists comfort access keyless entry under the Signature trim on the website.
ABC Ya
Aug 18, 2006 08:36 AM
Special Agent Cooper
Sep 22, 2005 11:54 AM
zfxr
29
Nov 19, 2003 09:19 PM
azul68
Jul 30, 2002 08:51 AM
