R60 Help needed with main REAR seal
Old May 15, 2026 | 08:18 PM
Minir602014's Avatar
Minir602014
I have an oli drip form the weep hole on the bell housing, pretty sure it's the main rear seal. I don't see any oil running from anywhere else like the oil cooler, oil filter housing, turbo lines, oil pan gasket, main seal or valve cover that would pool there. Assuming
a typical mechanic charge would be 3-4k but the car is probably worth about 5. I would do it myself but I can't find any videos or directions on how to do this. Not even sure if it can be done without a lift. Does anyone know where I can find a step by step process to change the seal? It's a 2014 countryman s r60 automatic. Does the transmission need to be completely pulled out for this and what's the worst that can happen besides constant oil loss if not fixed?
Old May 16, 2026 | 04:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Are you 100% sure it’s not coming from someone else? Looks like a lot of oil on the outside of the housing there….
$3-4k seems about right for a shop to handle the job. You do have to drop the transmission to replace the rear main seal. This gets a bit more complicated in the Countryman due to the transfer case on the All4 models. I swapped the clutch in my Clubman on jack stands. You do have to get it pretty high to lower the subframe. you can check for videos of R56 clutch replacements to get an idea of what is involved. The Countryman is basically the same assembly, with the exception of the transfer case and rear driveshaft.
Old May 16, 2026 | 10:29 AM
Minir602014
Thank you for responding, I can't say 100% sure but 99% sure since I had already replaced the front main seal when I did the timing chain which I believe you actually helped me with, all gaskets on oil cooler, had turbo rebuilt with all new seals and lines, oil pan gasket valve stem seals, and walnut blasted the ports. Watching separate videos seems to be how I'm going to get the knowledge to do this, from what I'm putting together, a video on lowering subframe, transmission removal and clutch removal would be good places to start. I did see one guy who took the front end off to remove the transmission instead of pulling the whole subframe off. I don't have an All4, so I'm hoping that will be a bit easier. Also going to have to figure out any special tools, and how many stretch bolts I can't reuse. I'm also guessing the passenger driveshaft needs to be removed? Is there anything else I should consider replacing while doing this job since there will be so much stuff taken apart?
Old May 16, 2026 | 01:29 PM
ski.dive's Avatar
ski.dive
Take it to a MINI repair shop and tell them you have an oil leak, they will tell you where it's coming from for sure.
I had a leak that I thought was from the rear main, the shop told me it was from the oil filter, easy fix.
Old May 16, 2026 | 10:10 PM
Minir602014
Appreciate that but I'm 100% sure about the places it's not coming from,. I can put my finger in the weep hole and feel wet oil and see it on my finger when I run it across the inner ledge next to the flywheel. Even if it was leaking from somewhere else, the oil wouldn't travel up into the weep hole. In my opinion anyway. Maybe I'll scope it and see if that shows anything.
Old Yesterday | 03:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Clean it all up REALLY good, the take it for a longer drive and check it again. With everything cleaned up, might be easier to find where it’s coming from.
Old Yesterday | 05:40 AM
HausMD's Avatar
HausMD
Alliance Member
Veteran: Army
Your situation seems to be identical to what I experienced recently with my son’s 2014 R60 S FWD.
I first noticed the leak due to the amount of oil residue I noticed on the underside of the car when doing an oil change. After cleaning it all up I found it to be from that same weep hole and confirmed it using my borescope camera.
Fortunately the parts aren’t expensive. In addition to the rear main seal, the transmission bolts have to be replaced since they’re one time use. The cost of labor makes this project expensive since the subframe and the transmission has to be removed in order to access the seal. Unfortunately I don’t have a life high enough to be able to drop the transmission from the car but I was lucky enough to have a good friend nearby who owns his own MINI repair shop be able to do the job while I watched and learned. Not sure how these can be replaced without dropping the transmission since you have to make sure you don’t roll the new seal when inserting it and it’s safer to set the new seal with a special tool that pushes it in evenly.
https://www.facebook.com/share/1EpJk...ibextid=wwXIfr
Old Yesterday | 07:04 PM
Minir602014
Checked everything again and I am certain it is the rear seal. Thank you HausMD, those pictures helped a lot.They are pretty much exactly what my situation looks like. I don't have access to a lift either, so I'm hoping I can somehow get it up high enough. I was wondering if you replaced anything else while you were having the seal replaced. I was thinking maybe I should just change out the clutch and flywheel since I have to pull those out anyway. I was also curious if your leak started with a very minor drip and if it periodically got worse? When I noticed my leak I was changing my oil like yourself and it was maybe a couple drops a day. Now, about a month later it's probably about a teaspoon a day and it only drips right after it was driven (and probably while driving) I saw pictures of your sons mini on the Facebook link and I gotta say, it's a very clean looking car! Looks well taken care of. My trim is all faded on mine and the paint has seen better days.
Old Today | 08:48 AM
HausMD's Avatar
HausMD
Alliance Member
Veteran: Army
Being this was my son's car, he's the one who ended up paying for the repair costs but I will tell you it was significantly cheaper versus the dealership. Because of that, we opted to only repair the leak and not anything else there. We debated on replacing some of the suspension components like the tie rods and control arm bushings but they still had life and that's something I can do myself. I own a Quickjack 7000 and I can say that wasn't going to be enough lift to drop that transmission and remove it from underneath. Even then, even if it was, it would be very difficult to hoist it back up there without a proper stand to raise it back into position. I've attached some pictures to show you the full height of the quickjack to give you an idea.
The drip was very minimal but we never noticed it in the driveway or garage which leads me to assume it was very light while driving but enough to coat the undercarriage with an oil sheen. Yet, it was a matter of time before it became worse and the repair had to be done sooner than later as it was losing 1/4 quart of oil a week.
As for his trim, he used Cerakote wipes to restore the color on all the fender trims. He replaced the side scuttles with new OEM Piano Black pieces to include OEM Piano Black headlight and tail light trim pieces. He also replaced the front lip with the OEM R61 version and went a step further and separated the chrome trim front the front grill, sprayed it black with Plasti-Dip and reattached it. He loves that car and takes very good care of it and also doesn't neglect it when it needs something.
Attached Thumbnails Help needed with main REAR seal-img_5299.jpeg   Help needed with main REAR seal-img_5886.jpeg
S4LC3D0
R60/R61 Stock Problems/Issues
Nov 10, 2025 04:12 PM
AirborneMini003
Aug 19, 2025 05:41 AM
Nigel07MC
Jan 22, 2025 03:44 PM
Michaelh57
Feb 27, 2021 11:50 PM
jjcsnlynn
May 6, 2019 07:32 PM
