R60 2014 countryman
Old Jan 16, 2024 | 09:25 AM
Scooter24's Avatar
Scooter24
2014 countryman
I’m going to be new to the countryman side of our cars. I’m not familiar with them in anyway shape or form as I have a 2011 mcs. My fiancé really wants a countryman and we found one local that looks really nice and we are going to go look at it. The car is a 2014 with 100k miles on it, no accidents clean inside and out (from pics). The lady did have the timing chain done 10k miles ago and has receipts. Is there anything I should really look at with these cars other than the basic stuff? Any major issues with these cars that would steer me away from this year? It is a FWD car and idk if I should look for a all4 or not. I feel like it would be nice in winter time for her but then again my mini does amazing in winter with being FWD and a good set of snow tires. Any input would be great, thanks!
Old Jan 16, 2024 | 01:40 PM
Manual or Auto.
Timing Chain, water pipe, thermostat housing, and check the rear springs for rust. HPFP version and if its been replaced. Turbo good? Boost and spools. Lived at MINI dealer?
Other then that has it been oil changed all the time 5-7K, not 10-15k intervals.
Wear and tear stuff. Good luck.
Old Jan 16, 2024 | 02:01 PM
Scooter24's Avatar
Scooter24
Any ways to identify HPFP age? Part number? I’m not sure if she is original owner.
Old Jan 17, 2024 | 07:55 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If its a 2014 car, then it has the newer HPFP.
Really, the Countryman is just a bigger R56 - similar platform, just bigger. Check to see what kind of service history the car has for oil changes. Regular (5000-7500 mile) oil changes are a must for these engines. If she drove the car and never checked the oil level, or waited for the service light before taking it in, I'd be nervous about the engine health.
Would you be performing your own servicing? That will also play into my recommendation. German cars with over 100k miles will be EXPENSIVE to maintain unless you do it yourself.
Old Jan 17, 2024 | 08:04 AM
Scooter24's Avatar
Scooter24
Yeah I do all my own stuff so that definitely saves money she says the car got oil changes every 3k miles so hopefully that is true. Ima pull the oil fill cap and take a peak and see how clean or dirty the top end of the end is. Is it better to get a all4 over the FWD model?
Old Jan 17, 2024 | 08:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
ALL4 vs FWD... Personal preference. The FWD model will be less complicated, so maintenance will be simplified, since you won't have to deal with the transfer case and rear axel. FWD is probably just as capable in the snow with proper tires.
Old Jan 17, 2024 | 09:34 AM
2014 MC's Avatar
2014 MC
I have a FWD base model and chose simplicity for my daughter (without the various turbo issues and transfer case driveline issues etc.). There are enough other aspects to worry/contend with to keep you busy.
Old Jan 17, 2024 | 12:47 PM
yep.
Should have this design: 13518605102
https://www.ecstuning.com/News/MINI_...el_Pump_22527/
Stepheno1514
Mar 29, 2023 09:36 AM
Mag3
May 17, 2022 05:57 AM
Ellen OSullivan
Oct 23, 2019 07:44 AM
dandw2
Sep 7, 2015 11:14 AM
