R60 Multiple codes; where to start
Old Sep 1, 2023 | 05:19 AM
trackntrail65's Avatar
trackntrail65
Just purchased an ‘11 r60 S from owner that said it has a possible blown head gasket. There are multiple codes and are as follows: p1447; p2270; p2402; p013a; p013e; p0136; p0128; p0117. In general they are oxygen sensor, coolant temp and thermostat, O2 sensor, and DMTL related codes. Previous owner says car began smoking; thinking steaming, near the intake manifold area and the overflow tank emptied itself into the system. Oil is clean; no chocolate shake anywhere. Car runs at full power when codes are clear however re-flashes quickly. Any ideas from the folks here on where to start with diagnosing this car? Thanks in advance.
Old Sep 1, 2023 | 05:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
P2270, P013A, P013E, P0136 are faults for downstream O2 sensor... I would replace that sensor.
P0128 and P0117 are related to coolant temp sensor and thermostat, which could mean a failed sensor and/or thermostat. I would plan on replacing those two items. You should include the coolant cross over pipe in your parts list, too. (I assume you will be doing the work yourself) If the car was "steaming" near the intake manifold, its possible the cross over pipe either cracked or failed somehow.
Old Sep 2, 2023 | 05:56 AM
trackntrail65
Thanks for the response. Borescoped the cylinders after a short drive and found #4 would steam over the lens. Also the added coolant continued to disappear from the overflow. Planning a head removal and inspection. The Bentley service manual has much of the needed information for the 2011 n18 engine.
Old Sep 2, 2023 | 06:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Dang, does sound like the head gasket. Hopefully nothing is really damaged. Take note that many of the bolts are single use, torque to yield bolts. Make sure you have new ones on hand for reassembly.
Old Sep 19, 2023 | 06:44 AM
jawilli6's Avatar
jawilli6
TracknTrail65,
Where does one find the service manual you mentioned? Mine is a 2013, but I'm looking at head removal as well, and haven't been able to find such a manual.
Best of luck to you.
redwhiteR562007
May 2, 2022 05:04 AM
idickers
Jun 13, 2021 07:14 PM
John P. Levesque
Dec 30, 2019 09:58 AM
manolo4350
European MINIs
Nov 14, 2013 12:03 PM
jaycobb38
Dec 7, 2010 09:07 AM
