R60 In need of some help please
Old Dec 7, 2019 | 03:17 PM
7rhSon's Avatar
7rhSon
So recently I've noticed on start up whether it be in the morning or after work (after the car has been sitting for several hours) as I start to drive and apply some pressure to the gas pedal I seem to get this strange revving type thing happening, like if I was pumping the gas pedal. It doesn't happen any more once the car is warmed up. Now.. I have applied more pressure to get passed this strange revving thing.. any thoughts?
Old Dec 7, 2019 | 05:15 PM
N41EF's Avatar
N41EF
The gas peddle is electronic, no cable. Could be a dirty resistor in the pedal assemble. You don't have a sprint booster on it?
With the car off before you put the key in, work the pedal to the floor and back several times. The put key in, start car and drive off, see if that helps.
Old Dec 7, 2019 | 05:22 PM
7rhSon's Avatar
7rhSon
Not even sure what the sprint booster is.. lol.. so I will say no.. but will try that trick you laid out
Old Dec 8, 2019 | 08:37 AM
7rhSon's Avatar
7rhSon
So I gave that a shot and no change. It only happens for a short period of time as I begin to drive upon start up i get up to about 2rpms and it's like a fluttering hesitation for lack of a better term at the moment.. is strange.. you can watch the rpm needle climb slowing and back down slightly and if I give it more gas it goes away.. i will try to take a video of it in the morning to show and perhaps someone will shoot me some ideas
Old Dec 15, 2019 | 08:35 AM
7rhSon's Avatar
7rhSon
So what is actually seems to be happening is that the turbo is oscillating, which could be an issue with vacuum lines I'm assuming.. it only happens on cold starts.. any thoughts?
Old Jan 5, 2020 | 07:58 AM
7rhSon's Avatar
7rhSon
It seems that it's my turbo oscillating. Vacuum issue I believe, I'm going to replace my vacuum lines 1st
Old Jan 12, 2020 | 12:34 PM
iwashmycar's Avatar
iwashmycar
Check that you dont have a cracked intake tube or the like. Pretty common area to break and leak.
Old Jan 12, 2020 | 01:33 PM
7rhSon's Avatar
7rhSon
Thanks for that bit of information.. will definitely check that out.. it only oscillates briefly upon the cold start when driving in the beginning. Once I push through it, it happens no more during the drive
Old Jan 12, 2020 | 01:42 PM
7rhSon's Avatar
7rhSon
You're referring too the air intake tube/boot/pipe that the air mass sensor attaches too
Old Jan 13, 2020 | 07:00 AM
iwashmycar's Avatar
iwashmycar
Yeah, but where it connects to the turbo typically breaks
Old Jan 15, 2020 | 03:17 PM
7rhSon's Avatar
7rhSon
So I changed out the air intake tube and still get the brief oscillation.. could/would the turbo boost converter solenoid valve give this issue if it was starting to crap out?
Old Feb 16, 2020 | 01:40 PM
sukhoikris's Avatar
sukhoikris
Does this cause a whistle to occur? My Mini has learned how to whistle when it's warming up. It's not a happy sound, nor is it cute.
Old Feb 17, 2020 | 11:31 AM
iwashmycar's Avatar
iwashmycar
Anything is possible....easy to figure out by simply running your hand or a rag over the area while its whistling...see if it stops.
At idle I am not sure it would really pull enough to audibly whistle, but I cant say for sure. Might also verify it isnt coming from the belt/pullies.
romero.riche
Nov 24, 2017 03:33 AM
tgalatis
12
Feb 7, 2013 01:05 PM
paddy06
Aug 2, 2011 07:44 PM
JOHNHOF
St. Louis MINI Club
Feb 28, 2011 06:00 AM
joeycola
Apr 18, 2007 02:07 PM
