R60 my automatic transmission wont grab
Old May 7, 2019 | 02:37 PM
OreoSAll4's Avatar
OreoSAll4
so i was driving down the highway and my coolant cap failed and spewed all over the transmission. as it was doing so i lost power and it started to slip and gave me a p0741(checked when i got home). decided to do a coolant system overhaul while it was out of commission and replaced the thermostat/crossover pipe/expansion tank as well as a few other things that needed attention. buttoned everything back up and she started up and warmed up nicely. took it out for a spin and the transmission was slipping!! it got to the point where i needed to keep the hand brake up and rev the engine until i felt it grab for it to accelerate. it was a quick trip around the block with a new problem. the transmission has never been an issue with the car and i can only think that "MAYBE" the plugs directly under the coolant tank shorted something out? anyone have any ideas what i should do? ill be checking the fluid and maybe do a transmission flush while im at it.
also, the code never came back after the test drive even though it was slipping.
thanks!
2012 Mini Cooper Countryman S All4
150,xxx miles
Old May 7, 2019 | 03:11 PM
Minidogger's Avatar
Minidogger
I would change the ATF before doing anything else.
Old May 9, 2019 | 01:25 PM
OreoSAll4's Avatar
OreoSAll4
Updates will be posted here https://www.northamericanmotoring.co...late-milk.html
kpmcl
Feb 23, 2016 09:16 AM
resmini
Sep 28, 2005 04:27 PM
kyriian
Electrical
Aug 18, 2005 01:31 PM
gnhovis
Tires, Wheels, & Brakes
Jul 21, 2005 05:04 AM
