R60 Manic Tune and Sprint Booster
Old Jan 18, 2017 | 08:00 AM
cstrumol's Avatar
cstrumol
Hey everyone,
Been thinking about getting a sprint booster for a bit now but plan on doing a manic stage 2 tune by the end of the summer. My question is, those that have the tune, is it possible to tune the throttle response? In essence, if I get a tune, will I no longer need the sprint booster? Don't want to buy parts and sell them in a couple months. Thanks!
Old Jan 18, 2017 | 08:54 AM
808keith's Avatar
808keith
it would remap the throttle to a linear response so you might be able to do without the sprint booster and get a intercooler instead
Old Jan 18, 2017 | 09:46 AM
Saltysalt's Avatar
Saltysalt
you shouldn't need both, the tune should change the throttle position
Old Jan 19, 2017 | 05:44 AM
cstrumol's Avatar
cstrumol
Thanks everyone, saved me $300 and the hassle of reselling!
Old Jan 19, 2017 | 04:27 PM
Mini Mania's Avatar
Sprint Booster Version 3
The Manic Tune is an ECU software upgrade which increases HP and improves throttle response but to a limited degree.
I have not seen any ECU tune improve the throttle response like the Sprint Booster. Those who have never tried the SB might believe it is redundant, but in actuality, the SB is much more effective in the throttle response area. They are 'complementary' products.
The Manic Tune big feature is the increase in HP.
Hope this helps!
http://new.minimania.com/part/SPRMI0...55-F56-F54-F57
Drive Hard. Drive Save. Keep Grinning.
Old Jan 19, 2017 | 04:42 PM
yesti's Avatar
yesti
The stock throttle map (versus pedal input) is not linear, which makes the car twitchy since it simulates you pressing the pedal more than you actually are. While this may be "fun" and give the impression of responsiveness, it can make the car hard to drive smoothly at mid pedal throttle position (on/off feeling). The manic tune smooths out the throttle map so it is easier to modulate. If you dont like the linear map, the sprint booster can give you back some of the exaggerated throttle response, depending how you set it. It can even go the other way (eco) I believe if you want to save gas. Try the tune by itself first then decide if you want to adjust response with sprint.
Old Jan 21, 2017 | 08:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The tune will improve the throttle response. So I do recommend doing the turn first and then seeing if you want more response. If at that point you do you can add the sprint booster.
When you're ready let us know as we turn the tune around in 24hrs
https://www.waymotorworks.com/perfor...e-r60-r61.html
We've had customers that go either way. Many get the tune then resale the Sprint Booster, and had some that use it with the tune and love to play with it. So it will be up to your butt dyno
Old Jan 23, 2017 | 07:27 AM
y8s's Avatar
y8s
Manic can probably write a linear throttle map into the tune you buy. Ask them.
Old Jan 23, 2017 | 04:56 PM
yesti's Avatar
yesti
Manic tunes already have a linear map. Helps modulate all that new found power !
Old Jan 23, 2017 | 05:05 PM
MarioKart's Avatar
MarioKart
Vendor
I removed the SB after the tune. The both together made the car too jumpy and unpredictable around parking lots and corners
mQubed Motorsport, Manic Tuning Dealer
