R60 2011 Countryman Electrical problem
Old Jun 18, 2015 | 02:37 PM
eesdrop's Avatar
eesdrop
Electrical Problem, windows, headlights, interior lighting Help! I took my car to an independent mechanic to change out the clutch and now I'm having electrical problems. He tried clearing it all with his handy little plug in computer thingy but windows won't go up, headlights won't go off, my dash lights won't go on, my turn signals don't work, and my interior lighting doesn't work. My mechanic checked the fuses and everything seems to be fine.
I have searched all the forums here and I've already tried resetting the windows by holding them in the up position, I checked my Mini Connect system and that doesn't work. My Nav has never worked and now this. Yeesh!
Any suggestions??
Old Jun 22, 2015 | 10:50 PM
minicountry's Avatar
minicountry
Sometime the battery is the culprit
Old Jun 22, 2015 | 11:10 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Agree, check the battery for volts and more importantly amps. If it is original it might be about to die.
Old Jun 22, 2015 | 11:14 PM
eesdrop's Avatar
eesdrop
Ok, thanks for the suggestion. Yes the battery is original.
i will have it checked!
Old Jul 7, 2015 | 01:38 PM
svntsvn's Avatar
svntsvn
Keep an eye on your windows, both of my minis that sufferered a low battery, have had the windows and moon roof open slowly overnight, not a good time if it rains. Always had enough to start, no warning light, so it always came as a surprise if a battery prematurely lost charge.
Old Jul 8, 2015 | 05:11 AM
Did you load test the battery and have tested for voltage ?
Cutelildevil666
Sep 12, 2015 09:36 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 12, 2015 01:24 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
