R60 Differences between 2014 and 2015 R60?!
Old Apr 22, 2015 | 09:33 PM
tgoodspe's Avatar
tgoodspe
Hey there everyone,
I'm getting a Countryman in the near future and have had my sights set on the new 2015 CMS. I've specced it out how I want dozens of times, etc. etc. Just recently I came across a 2014 CMS that's specced out just like my 2015 CMS (minus the JCW exterior/interior packages, different seats too), has all the important stuff I want on it, has such low mileage in might-as-well be a brand new vehicle, and I could get it for at least $11,000 less than what I would spend on a 2015 CMS.
So my question is, what are the actual differences between a '14 and '15 model? I can't seem to find any other than the chrome bar on the front grill. I still might go with a brand new '15 regardless, but this '14 is really something to consider if there's no huge reason to go '15.
Thanks!
- tgoodspe
Old Apr 23, 2015 | 07:02 AM
The X Men's Avatar
The X Men
We were deciding between a 2014 and 2015 as well a while ago. If I remember right, the 2015 comes with front and rear skid plates, side lower trims, LED DRL and fog lights and black speedo.
Old Apr 23, 2015 | 07:30 AM
nd3boy's Avatar
nd3boy
The front/rear/side trims you mention are for All4 only...assuming you did not pick the JCW Exterior Appearance Package.
Halo DRL/Fog Lights
Black Speedo
New Colors
Check this write up: http://www.motoringfile.com/2014/07/...ations-photos/
Old Apr 23, 2015 | 09:08 AM
flav's Avatar
flav
You are 100% incorrect. The silver lower side trim pieces come standard on the 2015 ALL4 Countryman (not the 2014) but you can opt to leave them off.
Mechanically the 2014-2015 are identicle. Also of note, all the interior gauges backgrounds in the 2014 are white and in 2015 are a dark gray (much cooler looking i think).
There are some visual changes to front bumper as well. And the LED fog lights on the 2015 are a nice touch but not necesary.
If it were me Id save the $$$ and go 2014. The lower silver trim is meh and I think looks better without it. However the dark interior color of the gauges on the 2015 looks really really nice, but not $11,000 nicer.
Old Apr 23, 2015 | 09:15 AM
tgoodspe's Avatar
tgoodspe
Also, one of the biggest things I want are the JCW exterior packages, which this 2014 doesn't come with... but isn't it true that I can have a Mini dealer order a JCW exterior package for me and do the install? If that's the case, then the 2014 is definitely worth it, because that's really the only thing that's bugging me that this guy is definitely missing.
Old Apr 23, 2015 | 10:57 AM
nd3boy's Avatar
nd3boy
You can order all the parts for the JCW Exterior Package. I believe the side skirt comes primed, un-painted. Check out the link below, not sure if a dealership would charge you more (labor = $$$). Next step is to figure out wheels, if you want the JCW wheels. Prolly $400ish per wheel. However, they do look nice.
Hopefully you can see this: http://www.shopminiusa.com/PRODUCT/1...CenterId=27600
Old Apr 23, 2015 | 03:35 PM
nlam2001's Avatar
nlam2001
Hey there everyone,
Thanks!
- tgoodspe
Little off topic, i purchased a 2015 countryman, i just found out the other day that if you coose the gloss black roof it might be a gloss black sticker, i took my countryman to changed the roof color and was told by the mommentum mini body shop in houston that is a sticker. In other words it will be expensive to change the color of the roof, i wish mini would disclose this on their website when building your mini.
Old Apr 23, 2015 | 08:56 PM
flav's Avatar
flav
A sticker? As in a large perfectly fit decal? Very doubtful. Proof?
Old Apr 24, 2015 | 03:27 AM
nlam2001's Avatar
nlam2001
The advisor at the body shop showed me the outline ofvthe sticker, if you lift your tailgate and you looked were the gloss black meetd the body paint you can clearly see the stucker or wrap, i did not believe it until he showed me.
Old Apr 24, 2015 | 11:44 AM
siriuszero's Avatar
siriuszero
Whaaaat? Are you sure it's not just the spray pattern? I think this body shop guy is pulling your leg or has no idea what he's talking about...
Old Apr 24, 2015 | 12:04 PM
nlam2001's Avatar
nlam2001
I think you are right, the funny thing is that he wrote it on the quote sheet.
Old Apr 24, 2015 | 12:17 PM
DWooderson's Avatar
DWooderson
$11,000? That's a lot of scratch!
I'd put that in your pocket, and enjoy the 2014. The 2015 will be last year's model in a few months anyway.
$11,000 could go a long way towards youification parts, a JB+ coilovers, brakes, etc (if that's your type of thing).
I've seen some nice aftermarket speedo gauge faces too, so if you want something other than white, that's possible.
Old Apr 25, 2015 | 07:50 AM
tgoodspe's Avatar
tgoodspe
That's what I was thinking. I figured I can get this vehicle for (maybe) around $27,000 versus minimum $37,000 for my spec'd Cooper S. I can put $3,000 in aftermarket parts on it (like I was planning to do for the 15 anyway) and make it faster than even the 15 JCW by far. Then, if I want, I can spend another $3,000 on the JCW bodykit and still be only at $33,000 for what appears to be (for all intents-and-purposes) the same car (between the 14 and 15 models).
Old Apr 28, 2015 | 05:35 AM
The JCW exterior package is here:
MINI Countryman JCW Style Aerodynamic Package For S, SX Primed - Sold As Kit 51192180855
http://www.ecstuning.com/Search/SiteSearch/51192180855/
There is also a factory Painted kit which only come in "Light White "
MINI Countryman JCW Style Aerodynamic Package For S, SX Painted Light White - Sold As Kit 51192210567
http://www.ecstuning.com/Search/SiteSearch/51192210567/
So the painted kit is something you could bolt on in your driveway or garage.
No other pre-painted kits at this time.
Installed PDF attached.
File Type: pdf
Old Apr 28, 2015 | 12:43 PM
tgoodspe's Avatar
tgoodspe
Thank you for this! This is really great to know.
Do any of you know if the lounge seats can be bought aftermarket? This is one of the biggest issues as the Countryman has the sport seats, but I'd really want to put the lounge seats in, it's a big deal breaker...
Old Apr 28, 2015 | 12:53 PM
Welcome.
The seats for the front share the same mounts. If you have the rear seats it should be the same for the 2 seat to two seat and 3 seat (bench ) to 3 seat. The seats are not one part number but a ton of part numbers that are piece together and its very expensive from MINI.
Good luck.
Old Apr 28, 2015 | 02:50 PM
tgoodspe's Avatar
tgoodspe
Welcome.
Good luck.
Where can I actually buy them from Mini though? And how expensive are they roughly?
Old Apr 29, 2015 | 07:59 AM
molala's Avatar
molala
Hey there everyone,
Thanks!
- tgoodspe
A yr ago i was in the market looking for a used R60. Was lucky and found one and right after i purchased it I drove straight to local Mini dealership and ordered the JCW kit. Be sure you talk to them and ask for a discount and or look at your local Mini dealership site as they often have specials/coupons. They will quote you price of the kit, with or without install and labor etc. Front and rear bumpers comes painted, side skirt needs to be painted. I went through the dealer for the kit, paint and installed. I got many motoring gear, parts, and accessories from the dealership and have always gotten a pretty good discount. You just have to ask and talk them into it.
Yea, I would for sure look into a 14 and save up the $11000. Not worth spending that additional IMO. I was in the same boat as you are now since i picked up my 13 last yr, with low mileage and pretty much fully loaded (to my surprise) for about yr price.
Old Apr 29, 2015 | 08:10 AM
molala's Avatar
molala
My 13 is gloss black roof and not a sticker. BUT i have seen people apply wrap/sticker on top of the roof. I saw it 2x AT the dealership showroom/floor. I even went to talk to them about pricing and if they were Mini staff (nope, 3rd party local ppl). They were wrapping the roof of a new Mini. I think it still comes in the black but when ppl want to change the color or style of the roof they then apply a new color layer on top of it.
Old Jun 8, 2015 | 06:38 AM
Just wanted to let people know we have the JCW Countryman Aero kits in Pre painted Light White on Super Sale + Free Shipping* ( contiguous U.S. only. ). 51192210567
Fits MINI Countryman S / SX (ALL4) 2011+
Old Jun 10, 2015 | 05:24 AM
Still have some left, limited quantities.
Old Jul 14, 2015 | 10:03 AM
Few left.
Old Aug 1, 2017 | 06:42 AM
Just a heads up, we have 51192180855 The Factory primed JCW body kit like the one listed above primed and ready to paint, its free shipping within the contiguous USA. Get them while they last!
52% off and Free shipping.
https://www.ecstuning.com/b-genuine-mini-parts/mini-countryman-jcw-style-aerodynamic-package-for-s-sx-primed-sold-as-kit/51192180855/
Installed and painted.
Old Sep 27, 2017 | 05:41 AM
Still have a couple left ^^
Old Jan 25, 2018 | 06:27 AM
Back in stock!
chrisx18240
26
Mar 16, 2022 09:56 AM
Aug 13, 2015 12:57 PM
Aug 13, 2015 12:56 PM
Aug 12, 2015 01:24 PM
