R60 Countryman Wheel Size
Not sure you can put 16s on a Countryman; stock wheels are 17s, with 18s optional. The first thing to consider for a softer ride would be putting on some non-runflat tires. I'm sure others will have more input, but the tire reviews on Tirerack could be a starting point for selecting softer-riding tires.
16s work and are available. More common in Europe.
http://www.minigenuineparts.co.uk/mi...oy_Wheels.html
But 15s wound not due to due to brake size.
i run mini oem 16 inch euro alloys for my winter tires on my all4
in the usa, ecstuning.com carries both the mini oem euro alloys and steelies
steelies are about $100 ea
alloys are about $220 ea
All4 Wheel SIze
Thank you all for the help
Had done away with the run-flats already
My area of New England seems to be spotted more heavily this year with pot holes - have done in two tires already
Hoping that a combination of more sidewall will help with some of the damage and provide a bit of a softer ride
thanks again
thanks again
Absolutely - really enjoying the relative comfort of the MINI 16" steel winter wheel set (non run flat tyres). I only ran for a month of the 18" turbofans and RFTs before swapping over wheels but it rides pretty awful on UK roads on the 18s.
The winter wheels are 7Kg less each than the summer wheels - combine that with RFT versus nRFT and an extra 1" of tyre wall depth its no wonder the ride is so much better
Can Countryman JCW run 16-inch steelies or is it restricted to 17 inch? Tirerack.com doesn't even offer a 17-inch option when you enter vehicle year and model. 1010tires.com (Canadian site) states that 17-inch wheels fit.
Need input from folks with experience. Thanks
Its can take 16" on the OEM steel wheels. The front caliper is like the same size as the Cooper S on the R60.
https://www.ecstuning.com/Mini-2015-Cooper_Countryman-R60-John_Cooper_Works-Hatchback-L4_1.6L_N18B16C/Wheels/OEM_Steel/
Welcome.
Mini'mon
Aug 16, 2015 04:15 PM
