R60 Forge BOV adapter!?
Old Dec 28, 2014 | 02:25 PM
pico33's Avatar
pico33
Forge BOV adapter!?
Does anyone using it now?
I am new, I want to put it on my countryman.
Some people claimed the oil will spit out from the release holes. Is that true?
Is this product really help the engine?
Any downside?
Old Dec 28, 2014 | 07:59 PM
Roxspin72's Avatar
Roxspin72
Pico,
Do a quick search on this;
BLUF, don't di it. Just a noise maker. Pending what mods you have so far; I would Get a hot side Boost tube resonator delete instead. That along with a good dri drop in filter would be your best bet for cheap and practical mods...
Old Dec 29, 2014 | 03:22 AM
Indimanic's Avatar
Indimanic
No oil from that area of the turbo
I have one u can have for 30
Old Jan 2, 2015 | 01:32 AM
Mojo'jo'jo''s Avatar
Mojo'jo'jo'
is the BOV a hard job to do? and is it worth it? I have intake with catless dp w/manic tune 2.0
Old Jan 2, 2015 | 06:54 PM
Roxspin72's Avatar
Roxspin72
Not hard with the right tools and patience... I recommend doing the Alta uprated spring = $20 ish, It will out last your stock DV, while adding improved performance and the capability of withstanding increased boost pressure👍 if your stock DV diaphragm fails remove spring add to new OEM DV= $69.00 and reinstall = Solid Results...👌
Old Jan 3, 2015 | 12:35 AM
Mojo'jo'jo'
You have any links for install on spring and DV? sounds like a good deal to me.
Old Jan 3, 2015 | 12:50 AM
Mojo'jo'jo'
I cant find any for a R60, are they all the same? and where can I gt the DV for 69$? thanks for the info
Old Jan 3, 2015 | 08:27 AM
Roxspin72's Avatar
Roxspin72
You would be looking for N18, R60 and R56 share the same Motor. I don't have a video, but I'm sure there is a write up somewhere. Pretty straight forward, hardest part is gaining access to the three hex bolts mounting the DV to the Turbo...
Old Jan 8, 2015 | 12:36 AM
Mojo'jo'jo'
thanks for info. just ordered it. Any other suggestions? after this thinking of doing my inter cooler. but I think that's as far as I go with big mods. any wor on how the tran is handling the upgrades ?
Old Jan 8, 2015 | 06:17 PM
Roxspin72's Avatar
Roxspin72
Interooler is a good choice. As far as my trans is concerned, no problems so far. I mostly do pulls in 2nd, 3rd and 4th. Too much power to lauch in 1st w/FWD. I am looking forward to a performance clutch and lightened flywheel in the future though, just because; 😁
Old Jan 12, 2015 | 08:25 PM
Mojo'jo'jo'
Talking
Up date. just got the spring, came with really simple directions (from Alta) had no problems taking it off. Results are wow, didn't think the spring would make that big of a diff but you sure can feel it. takes off even faster now. . now my wifes all "slow down, were gonna die". lol. thanks for the info. cooling the eng off to put better SP's in tonight
Old Jan 15, 2015 | 02:56 PM
Drnickm53's Avatar
Drnickm53
Good call on the Alta Spring. The Mod bug just bite me this last week. I am starting off slow, and the first thing I did was the Stiffy spring and the Alta Hot side boost tube. Those two made a huge difference. I did the tube first, really helped with off idle power and response, less turbo lag and the car feels a bit more responsive. The spring helped out too, it really helps minimize boost drop between shifts.
I do think if the diaphragm tears on the OEM valve I might just get the Forge unit. Seems to work a bit better, but not worth the $ or work right now with the upgraded oem unit working fan-freaking-tastic.
Old Nov 1, 2018 | 01:46 PM
AKoreanBoii's Avatar
AKoreanBoii
Any downside?
how did you change the DV? I know like how to do it but it seems they’ve made it super hard to change it in the Countryman. I can get my allon wrench to the bolts on the DV. ANY thoughts?
minimofo
Dec 26, 2015 12:03 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
micromini234
Sep 30, 2015 07:36 PM
