R60 Question for the exhaust guru's
Old May 8, 2014 | 07:53 AM
HorseWithNoName's Avatar
HorseWithNoName
I know a lot of guys pull the 2nd cat and the resonator off, has anyone pulled just the resonator and not the second cat with the stock muffler?
Old May 8, 2014 | 08:44 AM
pidge1114's Avatar
pidge1114
That basically the JCW exhaust, since the mufflers are the same and all it does is delete the resonator.
Old May 8, 2014 | 09:44 AM
HorseWithNoName
I didn't know that...
What I'm trying to achieve is more exhaust sound than stock but less than a full 2nd cat and resonator delete without torque loss. So do you think removing just the resonator would achieve that?
Thanks...
Old May 8, 2014 | 10:55 AM
pidge1114's Avatar
pidge1114
Thanks...
Yup! People have eliminated the resonator with increased popping and burble from the exhaust. Then get some nice tips to weld on and call it a day.
Old May 8, 2014 | 11:12 AM
HorseWithNoName
Thanks....
Old May 8, 2014 | 11:13 AM
ayk07's Avatar
ayk07
yeah im doing that too, was going to cut the 2nd cat off but will get problems here in NC,
if we do just do a resonator delete, is it better to just run a straight pipe or use a magnaflow resonator?
Old May 10, 2014 | 12:17 PM
HorseWithNoName
Removed the resonator and not the 2nd cat, disappointing results.
The sound level is unchanged, the deepness in the exhaust note is gone.
Old May 10, 2014 | 12:21 PM
Mark Gallo's Avatar
Mark Gallo
I installed the JCW exhaust and the Akrapovic down pipe WITHOUT removing the 2nd cat. Sounds decent but I want more. I will be removing the 2nd cat next week.
Old May 10, 2014 | 02:12 PM
HorseWithNoName
Removed the resonator and but not the 2nd cat, disappointing results.
Maybe I should have removed the 2nd cat and not the resonator?
Went back and removed the 2nd cat also, sounds good and not noisy at all. Also did a local emissions check and pass with flying colors.
The R61S seems much quitter than a 2nd cat and resonator removal then on the R56S, hope I don't have a loss of torque?
Last edited by HorseWithNoName; Jul 9, 2014 at 12:57 AM. Reason: Update and Auto correction corrections
Old May 11, 2014 | 10:41 AM
DiabloR60s's Avatar
DiabloR60s
Can you guys direct me to where my resonator might be for my 2014 Countryman? I'd like to remove it and install some bigger tips. Thanks.
Old May 11, 2014 | 10:43 AM
DiabloR60s's Avatar
DiabloR60s
Where did you purchase the Akrapovic down pipe from?
Old May 11, 2014 | 10:50 AM
Mark Gallo's Avatar
Mark Gallo
Way Motor Works
Old May 11, 2014 | 10:53 AM
Mark Gallo's Avatar
Mark Gallo
Here:
Attached Thumbnails Question for the exhaust guru's-tumblr_ltrm0eucsn1qf3wrko1_500.jpg
WestfaliaR
Aug 19, 2015 08:01 AM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
papawhiskey
Aug 10, 2015 09:31 PM
