R60 Change the side scuttle lights from amber to white?
Old Jun 12, 2013 | 07:09 PM
siobahn's Avatar
siobahn
So I just got my brand new 2013 Countryman (base) 4 weeks ago and I love it... except I am now kicking myself for not going with the "white turn signals" option because I totally HATE the amber colored lights on the side scuttle... (see attached photo for exactly what I mean)
Is there any way I can change this (to white), whether it be an aftermarket solution or could I even do it through the dealer? I've already tried researching this forum for solutions but couldn't find any exact answers, so I'm appealing to the community for any knowledge you may have!
Many thanks!
Attached Thumbnails Change the side scuttle lights from amber to white?-img_20130612_190537_264.jpg
Old Jun 12, 2013 | 07:17 PM
CR&PW&JB's Avatar
CR&PW&JB
Several vendors sell clear lenses for the side scuttles with an orange bulb for the hardtop MINIs. Assume some have developed and sell them for Countryman too.
You've done a search on the internet already, I assume.
Old Jun 12, 2013 | 07:47 PM
Koopah's Avatar
Koopah
Originally Posted by siobahn
{snip}...Is there any way I can change this (to white), whether it be an aftermarket solution or could I even do it through the dealer?...{snip}
www.realoem.com is your friend!
Look HERE.
Old Jun 12, 2013 | 08:32 PM
EHans's Avatar
EHans
Many thanks!
Wow. I am glad I got the xenon which changes it to white turn signals. I didn't really care about the yellow flasher in the front, but yeah, I wouldn't want the yellow lights on the side. I don't think the online configuration tool made that clear.
Old Jun 12, 2013 | 10:57 PM
DKIKK77's Avatar
DKIKK77
http://mini.sewellparts.com/oem-cata...-R60-2012.html
Old Jun 13, 2013 | 04:28 AM
siobahn's Avatar
siobahn
Thanks all for the speedy replies - so I'm assuming (I'm a computer geek but not a car geek, so I am not super great with this stuff) that you are referring to the parts numbered 63139802569 and 63139802570?
Also - Does anyone know if these are easy to install? Are there any manuals out there or should I hire a pro?
Thanks again!
Old Jun 13, 2013 | 04:59 AM
PooLeArMor's Avatar
PooLeArMor
Thanks again!
very easy to install
just open ur hood and reach ur hand into the fender.. there is a lot of room back there.
Old Jun 13, 2013 | 05:06 AM
DKIKK77's Avatar
DKIKK77
Thanks again!
Yes. You would need 569 and 570. And they are easy to change. Each one has two clips. One at the top and one at the bottom then they just pop out and the new ones pop in.
Old Jun 13, 2013 | 06:50 AM
We have the clear ones right here. #1 in the diagram
http://www.ecstuning.com/Search/SiteSearch/63139802569/
Left Side
http://www.ecstuning.com/Search/SiteSearch/63139802570/
Right Side
They look pretty good on the Cooper S and JCW version Side Carriers which are the whole part.
#3 in diagram
Side Carrier Turn Signal Trim JCW - Left
http://www.ecstuning.com/Search/SiteSearch/51139808593/ES2627151/
Side Carrier Turn Signal Trim JCW - Right
http://www.ecstuning.com/Search/SiteSearch/51139808594/ES2627152/
Here what they look like on the Cooper S version side carrier to give you another idea.
Side Carrier Turn Signal Trim S Chrome - Left
http://www.ecstuning.com/Search/SiteSearch/51139804617/ES2136587/
Side Carrier Turn Signal Trim S Chrome - Right
http://www.ecstuning.com/Search/SiteSearch/51139804618/ES2136588/
Old Jun 13, 2013 | 07:37 AM
sbdubya's Avatar
sbdubya
Make sure to convert the bulb from orange to a silver off/yellow flash style so as to complete the look. The "white turn signal" option just means Mini puts a clear lens in, the bulb is still orange.
You can just spray paint the bulb silver or order them. I used sixity.com to get mine. Make sure to order the same type as you have in. Mini uses two different ones for the front but the sides are all the same.
Old Jun 13, 2013 | 08:36 AM
ASKtheteach's Avatar
ASKtheteach
ECS Tuning is your best bet. This is a simple swap that is very effective. FWIW, there is no such thing as a "base" MINI. They are all either S or non-S.
Old Jun 13, 2013 | 10:13 AM
Koopah's Avatar
Koopah
I use amber LEDs in my side scuttles. Since they are totally white until lit. They blend in perfectly. The amber and silver bulbs are still too noticeable for my taste.
Old Jun 13, 2013 | 03:00 PM
bguarino's Avatar
bguarino
I replaced my white ones with smoke/tint black ones. I can sell the ones I took off. Also they only take 2 minutes to remove and install, very easy. PM me.
Old Jun 19, 2013 | 07:30 AM
joshuabowman's Avatar
joshuabowman
is there a way to get just the JCW inlay?
Old Jun 19, 2013 | 07:50 AM
The JCW trim covers ( inlay ) only comes with the "Side Carrier Turn Signal Trim JCW" whole section as pictured above. You can get other inlays separately in sets. This will give you some options.
Mount set for trim panel: #1
http://www.ecstuning.com/Search/51132208400/
Or you can do just the inserts with the mounting set. #1 .
Yellow Cover Set Part number 51132184062
http://www.ecstuning.com/Search/51132184062/
Green Cover Set Part number 51132184058
http://www.ecstuning.com/Search/51132184058/
Orange Cover Set Part number 51132184060
http://www.ecstuning.com/Search/51132184060/
Blue Cover Set Part number 51132184059
http://www.ecstuning.com/Search/51132184059/
Pink Cover Set Part number 51132184064
http://www.ecstuning.com/Search/51132184064/
Union Jack Set Part number 51132184056
http://www.ecstuning.com/Search/SiteSearch/51132184056/
Black Jack Set Part number 51132184057
http://www.ecstuning.com/Search/SiteSearch/51132184057/
Old Jun 19, 2013 | 12:00 PM
bmrguy03's Avatar
bmrguy03
Do you have your original white/clear ones? If so, how much are you willing to sell them for? Thanks.
Old Jan 5, 2014 | 08:07 PM
mvice's Avatar
mvice
Anyone knows how to remove and replace the color covers?
Old Jan 6, 2014 | 07:39 AM
It looks like for the trim covers and multiple colors you can use the chrome mount set. But should fit an other version.
If you look at the back of the black jack set, you can see the tabs. And how they line up, then it should just snap in.
Let me know how it goes and I will try to help.
Old Jan 8, 2014 | 01:34 PM
illeagalhunter's Avatar
illeagalhunter
I changed my for the JCW ones , takes 10 mins to change
boostedhaze
Jan 2, 2018 07:26 PM
CM2011RG
Apr 12, 2016 12:44 PM
cm.d
Aug 19, 2015 08:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
CM2011RG
Aug 5, 2015 02:00 PM
