R60 Loose Gas Cap Warning & CEL
Old May 31, 2013 | 05:03 AM
bguarino's Avatar
bguarino
I did read a few posts about this topic, but they were pushing 2 years ago...so here it goes again
The other day while in the middle of a 20 minute commute a warning was displayed on the NAV and Tach screens. It read "Loose Gas Cap". It flashed a few times, then went away and I did not think anything of it.
The next day the CEL light came on and has since stayed on. I thought it was because of a loose hose since I installed a FMIC last weekend, but everything looks, sounds, and feels fine. I did leak a small amount of coolant installing the FMIC (pushing hoses around), but the [SIZE=3][FONT=Calibri]reservoir is right at the MAX line and MINI connect shows an engine temp of 190-210F after 15 minutes of driving.
Any thoughts on cause? Should I be worried enough to go to the dealer?[/FONT][/SIZE]
Old May 31, 2013 | 05:47 AM
Braminator's Avatar
Braminator
Have the CEL read by a scanner and that will help figure it out. If you don't have a scanner go to Advance Auto or some AP store like them that can read the codes. Then we can help you.
Old May 31, 2013 | 09:33 AM
bguarino's Avatar
bguarino
Auto parts store said it's an evap system error. No code #, does this help?
Old May 31, 2013 | 09:35 AM
psichick's Avatar
psichick
so here's a dumb question, did you actually check the gas cap?
Old May 31, 2013 | 11:16 AM
Braminator's Avatar
Braminator
Evap errors 9 out of 10 times it is the gas cap.
Old May 31, 2013 | 11:29 AM
ASKtheteach's Avatar
ASKtheteach
Agreed that it's the gas cap. If you have a Scan Gauge II or have access to one, you can use it to clear the code.
Old May 31, 2013 | 11:30 AM
bguarino's Avatar
bguarino
Yes checked the cap yesterday after getting the CEL . It was tight. I opened it, removed it, put it back on, and screwed it back down tight. CEL still on.
Getting a SG2 and will check then clear it..wanted one anyways. If it comes back, then I guess it's dealership time. I read stories that air gets trapped in the fuel pump and they have to replace it...
Old May 31, 2013 | 11:47 AM
Braminator's Avatar
Braminator
If the cap was lose and caused the CEL, it will take a few drive cycles to clear it.
cawwwtun
May 3, 2016 08:03 AM
embiggenedmini
Oct 15, 2015 12:36 PM
mrjolliff
Oct 9, 2015 05:55 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
