R60 No jack kit for 2013?
Old Jan 21, 2013 | 11:29 AM
shark715's Avatar
shark715
BMW replaced our troubled 2012 cmsa4 with a 2013 that we picked up this morning. The 2012 came with a jack but the 2013 did not, and the dealer said this is correct. I guess it can be argued that there is little need for a jack if you do not have a spare, although we would prefer the flexibility as we ordered non run flat winter tires a few minutes ago.
Have everyone else's 2013's been delivered without the jack? Why the change? Cost cutting? Weight reduction?
Old Jan 21, 2013 | 11:43 AM
bmwr606's Avatar
bmwr606
even with no spare, the jack is quite handy
if you get a flat and put the sealer in, it can help to spin the tire to aid spreading it around the puncture
also when filling a flat, either with one of those small electric pumps or from a CO2 cartridge, it fills much faster if the weight of the car is off the tire
scott
Old Jan 21, 2013 | 11:44 AM
Braminator's Avatar
Braminator
Does it have runflats? That could be the reason.
Old Jan 21, 2013 | 11:51 AM
bmwr606's Avatar
bmwr606
both my dad's and my 2012 cms all4s came with run-flats and jack kits
scott
Old Jan 21, 2013 | 11:53 AM
shark715's Avatar
shark715
yes, but so did the 2012.
Old Jan 21, 2013 | 11:58 AM
Braminator's Avatar
Braminator
Maybe you should check with another member or dealer who has a 2013 and see if they have one.
Old Jan 21, 2013 | 12:02 PM
bmwr606's Avatar
bmwr606
probably has something to do with the relocated window switches
scott
Old Jan 21, 2013 | 12:52 PM
iriedevil32's Avatar
iriedevil32
I never use the jack set that comes with a vehicle. They are flimsy. I have my own hydraulic jack since 1997. It's still going strong.
shark715's Avatar
shark715
I'm hoping that other 2013 owners chime in here.
Old Jan 21, 2013 | 02:00 PM
mr. jim's Avatar
mr. jim
No jack with 2013, my MA confirmed the day I picked mine up, he wasn't aware until we tried to find it.
Old Jan 21, 2013 | 03:32 PM
ckarlovich's Avatar
ckarlovich
2013 CountymanS.... NO JACK in mine either. I am a new MINI owner, when they showed me the trunk area, I asked about a jack....the MA said "there is no need for a jack with run flat tires." I had no idea they were available on previous models.
Old Jan 21, 2013 | 04:00 PM
youthanasia's Avatar
youthanasia
I picked up my 2013 today and no jack either.
Old Jan 21, 2013 | 04:48 PM
shark715's Avatar
shark715
Not only was the jack available last year, it was standard and so were run flats. Oh well, at least we like the new colors for the air conditioning vents and bezel around the speedometer, plus the now standard lumbar adjustment, and the revised window and mirror switchgear.
Old Jan 21, 2013 | 05:08 PM
Leader's Avatar
Leader
I took the jack kit OUT of my 2012 as soon as I got the car home from the dealer.
Space-waster.
Old Jan 21, 2013 | 05:14 PM
davidm52's Avatar
davidm52
I am curious as to the issue you had with your 2012 cmsa4. My 2012 has been in and out for service due to cylinder issues and rough running. So far 5 times in less than 8 months
Old Jan 21, 2013 | 07:26 PM
shark715's Avatar
shark715
Electrical system problems that they could never resolve...different fuses blowing causing the engine to stop. The Service Manager said they thought it was a bad ground, and at one point we thought all was resolved. But then it started again. Not frequent, perhaps every couple of weeks or so, and I began to recognize the signals the engine was about to quit (sputtering, etc.) I finally had to resort to carrying spare fuses with me while we waited for the replacement car to arrive.
I never heard of anyone else on this forum or otherwise having the same or similar issue, and we had no other issues with the car other than a minor issue programming one of the the Sirius radio presets. So we figured it was extremely unlikely we would run into the same issue again. When they offered to replace the car with a 2013, we assumed that would further reduce the chances of problems under the theory that they have now had several years to work through the glitches of a new model. Time will tell if we made the right decision...
Old Jan 22, 2013 | 01:33 AM
stouf63's Avatar
stouf63
Here in France, 2013 Countryman S and no jack either, but the dealer gave us one
Old Jan 22, 2013 | 04:24 AM
davidm52's Avatar
davidm52
I am glad to hear they did stand behind the cms. The jury is still out on my issues, but we will see... Happy motoring
Old Sep 29, 2013 | 03:01 PM
TJANK's Avatar
TJANK
2014 JCWCM-- no jack, no tools, and no spare
I just received my 2014 CM--and no jack, no tools, and no spare. MA said it was due that I have run flats and I can drive to a safe location. If I did not have run flats, they would have provided the Mini Mobility System (small 12 volt pump and a can of slime). This is no surprise since my 2008 BMW M Coupe had no spare but did come with BMW Mobility System (pump and tire slime). Interesting thing is that the owners manual does not even show how to jack that car and has remove the torque statements for tightening the lugs. It simply says "Your service center will be glad to advise you". This is different from an slightly older 2013 version I found online dated 10/12.
At least they left the tow hook.
Old Oct 4, 2013 | 08:58 PM
2fysh's Avatar
2fysh
2013 CM here and no jack. It was hard to believe at first but apparently that's what that roadside number on the huge sticker on the windshield is for.
Dec 23, 2015 10:36 AM
kyungmanpark
Aug 23, 2015 07:26 PM
mackedmini
Aug 20, 2015 02:35 AM
