R60 No Audio Through Speaker With New Apple iOS6 Maps
Old Oct 17, 2012 | 04:07 PM
copyace's Avatar
copyace
I have the standard Y cable and a Cable Jive extension -- and can't find a way to hear the turn-by-turn audio from Apple's new map app, though things work fine with other apps. What am I doing wrong? Thanks.
>>Brent
Old Oct 17, 2012 | 05:01 PM
Mojito's Avatar
Mojito
have you tried pushing the volume up on the phone while its in the app?
Old Oct 17, 2012 | 05:50 PM
kgelner's Avatar
kgelner
>>Brent
It should work, I get audio from Apple Maps using an iPhone 5 and the adaptor.
Old Oct 17, 2012 | 07:41 PM
MotoGreg's Avatar
MotoGreg
I assume you know, but just in case, the turn by turn audio only works if you have Siri, on the iPhone4S or iPhone5.
Old Oct 18, 2012 | 04:35 PM
80jpm's Avatar
80jpm
I have the 4S and I haven't gotten this to work yet either. Are there any settings on the phone I need to check? Does the radio need to be set to Bluetooth or USB audio source or can I listen to FM and have Siri interrupt the music when it's time to make a turn?
Old Oct 18, 2012 | 09:00 PM
mavic1010's Avatar
mavic1010
I used an iPhone 5 and it worked when I was streaming music through the system. It did not interrupt when using a different music source (FM/AM/Sat).
Old Oct 19, 2012 | 03:11 PM
copyace's Avatar
copyace
That's it, Mavic. Went to my Mini dealer today to find their iOS guru. He confirmed that at least on the Countryman, you can only hear the turn-by-turn directions through the car speaker when you have your playlist going and you select the iPhone under the CD portion of the main menu -- so no way to hear the directions when you're listening to radio, or have silence except for the directions. Thanks for the help, gang.
Old Oct 21, 2012 | 03:33 PM
80jpm's Avatar
80jpm
I got it working while listening to the iPod, but no joy with pandora. I recommend using the low voice volume setting
gar56
Nov 15, 2016 06:41 AM
minimofo
Dec 26, 2015 12:03 PM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
