R60 MINI Garmin holder
Old Oct 14, 2012 | 08:07 AM
R60All4's Avatar
R60All4
MINI Garmin holder
I recently bought the MINI Garmin Nuvi holder and I have the 12 page print out, however, the wiring is vague. Can anyone send me to an appropriate area, links are fine, I am unable so search from work more than 2 minutes without a boss questioning me. Pics or video would be awsome. Thanks in advance and happy motoring.
Old Oct 14, 2012 | 08:37 AM
FredoinSF's Avatar
FredoinSF
Did you check the mods section? Sometimes it's a better place than the talk section for how to's.
Old Oct 14, 2012 | 12:38 PM
R60All4's Avatar
R60All4
thanks for the quick reply. The posts about the MINI brand kit are leaving me with the same problem on the wiring. Unfortunately $165.00 for a part and nearly $200.00 for labor, I was looking to avoid. If I can't figure the wiring out, I'll return the part Monday.
Old Oct 15, 2012 | 10:58 AM
ball's Avatar
ball
I have instructions that I could take a picture of if you want. The dealer printed them out for me when I purchsed the mount. It took me maybe 15-30 minutes to complete from start to finish. I had installed the previous version on my old 2008 Clubman and this new mount is way easier to wire. Also, if you had a dealer close to you, have them print the installation instructions off.
Old Oct 15, 2012 | 02:29 PM
R60All4's Avatar
R60All4
If you could take pix of the wiring, I'd be set. I am unable to hit up the dealer til next month at the earliest.
Thanks for the help.
Old Oct 17, 2012 | 08:41 AM
ball's Avatar
ball
Old Oct 18, 2012 | 12:41 PM
R60All4's Avatar
R60All4
thanks ball! greatly appreciated. My MINI parts dept is severely slacking. Ive ordered several parts and all have been sent out incorrectly as well as completely wrong instructions. Thanks for the help.
Old Oct 18, 2012 | 12:59 PM
jcauseyfd's Avatar
jcauseyfd
Wiring into the OBD port instead of to the circuit panel - interesting. I guess that would be a switched power supply source that turns on and off with the ignition.
Old Oct 19, 2012 | 06:51 AM
ball's Avatar
ball
Word of advice. Do not take the garmin holder on and off (ball and socket parts). The plastic tabs that hold it all together are weak and cant take the force required to seperate and push together the ball and socket pieces. I think it was about 4-5 times before the plastic tabs broke, both on the grey outer ring and in the mount itself. Its pretty cheaply made. Im going to try and see if I can order replacement parts for it.
Old Nov 12, 2012 | 08:19 PM
pbedrosi's Avatar
pbedrosi
The used 2010 mini I'm about to buy has this kit installed but no Garmin. Do you guys know if you can install something newer than Nuvi 360?
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
cub4bearindiana
Aug 25, 2015 06:49 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Dashdog
Aug 10, 2015 06:17 AM
