R60 Tensioner 'recall' / oil drip
Old Sep 28, 2012 | 05:50 AM
Alien88's Avatar
Alien88
My Countryman started dripping oil. It was coming from the left rear of the engine if you were looking at the engine. Took it to the dealer, SA stated that there is a "recall" for it that recently came out. There is a known issue with the chain tensioner being too short and causing it to leak.
Paperwork says "M11 05 12, Check Chain tensioner leak". They said it'll take about an hour to fix. I haven't found much on the forums for this issue with the Countryman, but certainly lots of posts about earlier models regarding this.
Old Sep 28, 2012 | 08:03 AM
Mojito's Avatar
Mojito
Sounds like a service bulletin? There's nothing listed on the nthsa website about this
Old Sep 28, 2012 | 08:09 AM
UKM1NI's Avatar
UKM1NI
I had my 2011 MCS in for an inspection on Monday and I had a recall on the same part
Old Sep 28, 2012 | 08:34 AM
Alien88's Avatar
Alien88
Agreed, thats why I quoted 'recall'.
Final paperwork says "23759 FAULTY TIMING CHAIN TENSIONER SEALING RING REMOVED TIMING CHAIN TENSIONER. REMOVED AND REPLACED TENSIONER SEALING RING. REINSTALLED TIMING CHAING TENSIONER. PER SI M11 05 12."
So it would seem that all they did was replace the seal and not the tensioner based on the paperwork...
Old Sep 28, 2012 | 09:21 AM
shark715's Avatar
shark715
"SI M11 05 12" refers to a Service Bulletin published by BMW.
Service Bulletins are published to assist dealers, technicians and others to identify issues, correctly make repairs, and address customer concerns and complaints.
The specific Service Bulletin above is not associated with a recall (where owners are proactively requested by the manufacturer via mail and other means to bring their vehicles to the dealer for a specific update or inspection), but some Service Bulletins do refer to specific recalls.
In Alien's case the SA probably just used the term "recall" a bit too loosely, and simply meant that the dealer had received specific direction from BMW on how to proceed if they came across a car with this issue.
Old Sep 28, 2012 | 09:11 PM
Bakerbrdz's Avatar
Bakerbrdz
The recall is only to inspect for leaks....not replace...if its leaking, they'll replace
Took my car in last week for this...there's a SIM number for it
Old Sep 29, 2012 | 08:58 AM
shark715's Avatar
shark715
So you received a letter from the manufacturer (not the dealer) advising you of a recall? If yes, sounds like it's for a very small number of cars as I've heard no one else mention this recall. But that could be. I've seen recalls that involved as few as a couple of dozen cars.
Old Sep 29, 2012 | 03:15 PM
youthanasia's Avatar
youthanasia
Mine is @ the dealership right now for the 3rd time because of an oil leak.
First they said it was the drain plug, the 2nd time, they said it was the oil pan gasket, and this time, they're ordering a new oil pan because they think the oil pan is "warped" and won't properly seal even with the new gasket. The oil pan had to come straight from Germany (10 days to get here). Fortunately, they gave me a loaner. But it still sucks, the car only has 22k Kms on it.
Maybe this is the cause of mine. I will let them know.
Old Sep 29, 2012 | 04:25 PM
shark715's Avatar
shark715
Hard to beleive they could mix the two problems up. It's just a matter of putting the car up on the lift and seeing where the oil is leaking from
Old Oct 1, 2012 | 10:09 AM
dharvey1221's Avatar
dharvey1221
I have an oil leak on my 2012 CM with 13000 miles. Went in for an oil change and they said they needed to keep it for the coolant sensor recall. They then called back and said that they noticed oil on a wiring harness and they wanted to replace some sort of cylinder part. I guess the good news is that they noticed and are being proactive. Still dreading the day my car hits 46,000.
Old Oct 1, 2012 | 10:34 AM
sbdubya's Avatar
sbdubya
Took mine in for the Coolant Temp Sensor recall and had them look at the "weeping" gasket that the local Mini mechanic pointed out at an oil change. Ended up replacing the oil pump solenoid and the SA said he's been seeing a few of these. All of this before 1000 miles.
See this post concerning it:https://www.northamericanmotoring.co...noid-leak.html
Old Oct 1, 2012 | 10:35 AM
youthanasia
Yeah, as much as I love my car, I don't think I will keep it past the 4-year warranty.
Old Oct 1, 2012 | 08:22 PM
dharvey1221
Got it back tonight and it was the oil solenoid they replaced. Car is fine hopefully that's it.
Old Oct 2, 2012 | 05:59 AM
TXdirt's Avatar
TXdirt
it'll be time for a new one :-) I told my wife that and she said it'll be her turn for the new car. Told her we might just have to put the kids to work then.
Old Oct 4, 2012 | 06:05 PM
Mojito's Avatar
Mojito
Old Nov 7, 2012 | 11:39 AM
Kalamazoo All4's Avatar
Kalamazoo All4
I too, took my CM in for oil drips on my garage floor. They suspected it was the seal on the oil tensioner or the oil pump solenoid, as there have been numerous reports of each.
Mine was the oil tensioner seal. They also did the coolant temp sensor recall at the same time. Hopefully that will be all for awhile.
Kimolaoha
Jul 5, 2023 01:04 PM
Sailorlite
Sep 21, 2015 12:00 PM
Mrdi
Aug 29, 2015 03:18 PM
clintmeister
Aug 12, 2015 11:11 AM
kwijmbo
Aug 5, 2015 09:00 PM
