R60 Wheel fitment issue- please help.
Old Mar 11, 2012 | 09:19 AM
Kenningtons's Avatar
Kenningtons
All:
I am putting the OEM 17" rims back on my '11 S All4, and one of the rear wheels just won't fit. Something is preventing the rim from sitting flush with the hub. All the other rims fit. The wheel seems fine, as does the hub.
-Are the front & rear wheels different?
-Have you heard of/experienced this problem?
Thanks in advance,
Paul.
Old Mar 11, 2012 | 09:42 AM
Kenningtons
Fixed it. Turns out part of the winter rim (pressed in spacer) had stuck on the hub.
Why did Mini decide to use threaded lug nuts? Everyone else gave up on that years ago!
Old Mar 11, 2012 | 03:09 PM
stevepsd's Avatar
stevepsd
I think you mean threaded lug BOLTS....
anyway, Porsche still uses them, along with Audi and VW and probably others. It does make it a bit of a hassle to mount the wheels unless you have a screw-in guide to slide the wheel on (my Porsche has this).
Old Mar 11, 2012 | 03:53 PM
Kenningtons
I stand corrected. Threaded lug bolts. They're a PITA.
Old Mar 11, 2012 | 04:08 PM
stevepsd's Avatar
stevepsd
I agree, very much so.
Old Mar 12, 2012 | 09:06 PM
n1tr0's Avatar
n1tr0
If you work with them a bit, it's actually easier to mount and dismount wheels that use the bolts instead of studs. You just slap the wheel on and spin it until the holes line up. Of course if you're using cheap aftermarket wheels that don't have nicely machined/matching hubs it does become a real pita.
Kimolaoha
Dec 5, 2020 09:32 PM
ROCNDAV
Oct 20, 2015 01:08 PM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
