R60 Driving lights. Worth it or not?
Old Oct 22, 2012 | 09:18 PM
  #101
FredoinSF's Avatar
FredoinSF
I showed up and he had some already done that he put on. He also did te tail
lights and the window trim.
Here are a couple more pictures.
Old Nov 12, 2014 | 11:26 AM
  #102
fnscotsman's Avatar
fnscotsman
Originally Posted by threar
I don't have the OEM DL's, I have Hella 500 Black Magics, but I have protective covers on my lights (which I keep on all the time):
A very dirty front end.
Hi threar, any concerns or issues driving in Colorado with a four driving light setup? I'm considering putting this on my Countryman this year. State law only allows four total at any given time apparently. Also any issues with engine airflow with the four Hellas mounted?
Cheers.
Old Nov 13, 2014 | 09:12 AM
  #103
ghamma's Avatar
ghamma
Originally Posted by fnscotsman
...State law only allows four total at any given time apparently...
For 'legal' use the usual procedure is to enable power to the auxiliary lights separately, then the selection of fog or driving is done when you select low or high beams, respectively - that way only 4 lights are running at any one time.
They are a nice, traditional styling enhancement for a MINI, but the xenons do extremely well on their own...
Old Nov 13, 2014 | 09:57 AM
  #104
fnscotsman's Avatar
fnscotsman
Yeah I agree the Xenon headlights are brilliant. I think I will wire the driving lights to the high beam, however I will also wire a kill switch between them so that they are disabled for normal driving. Thus when I do use them they will come on simultaneously with the high beams.
Old Nov 13, 2014 | 05:33 PM
  #105
fishbulb's Avatar
fishbulb
This is a good set up, I have run 3 minis with hella 500s this way.
On my CM, I didn't even bother with running the switch into the cabin, just left it out of the system. If you ever need to "turn them off", just unplug the relay....
We have had Xenons on all our minis, but the Hellas really help on our deer infested back roads!
Old Dec 15, 2014 | 09:17 PM
  #106
wzabrouski's Avatar
wzabrouski
So I ordered the VIP quad light bracket for Hella 500's and unfortunately due to having the Alta intercooler, could not install the center bracket. After speaking with VIPS, this is a known issue. Has anyone worked around this issue?
Old Dec 16, 2014 | 08:50 AM
  #107
fnscotsman's Avatar
fnscotsman
I've got a set of Hella 500's (Black Magic) sitting under the Christmas Tree... Roll on Boxing Day!
Old Dec 16, 2014 | 08:57 AM
  #108
Jason Garrett's Avatar
Jason Garrett
I'm not a fan of the OEM driving lights honestly. But I will get driving lights on mine one day, probably way down the road, but I'll have a replica of this setup custom made from fiberglass:
Attached Thumbnails Driving lights.  Worth it or not?-mini-wrc_2011_800x600_wallpaper_01.jpg
Wohnson89
Jun 10, 2020 04:53 AM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
JHolland
Aug 13, 2015 10:47 PM
iclancy82
Aug 11, 2015 09:35 AM
