R60 CM Boot Dimensions?
CM Boot Dimensions?
Anyone have accurate measurements of the interior of the Boot with the seats up? I've searched around and only found one place online where they are posted and they sound suspicious to me. I asked my MA for them and he measured with the seats down and gave me a width narrower than my current Justa, so that can't be right. I need to figure out size limitations for a double jogging stroller, so obviously both rear seats will need to be up to accommodate the kids that will use the stroller.
I'm looking for width, height, depth with both back seats usable. I could have the flat load floor up and the parcel shelf/cover removed.
My next option is to go to the dealer and measure myself but I'm 9 months pregnant so I'd rather avoid the trek if possible. TIA!
I dont have the exact measurements but you can visualize here..
Interior Cargo Volume - 12.2 cu.ft.
Interior Cargo Volume w/Seats Folded - 41.0 cu.ft.
Pictures from http://blogs.insideline.com/roadtest...-s-countryman/
Thanks, the Keg picture is actually the most helpful I've found because I can figure out the dimensions of a standard Keg. Looks like its at least 2 kegs wide and 1 keg deep, so 32"+ x 16". I need a width of 34" so I'm probably ok.
Just an FYI for golfers out there, the CM is significantly wider than the non-CMs. I was at the dealer placing my order and I had my clubs in the trunk. The MA let me test fit the clubs and if you take the driver and 3-wood out they fit perfectly. The removed clubs then fit by just angling them up into the side window wells. I didn't try it but I think I could easily get 3 sets in this way without laying down the seats. The only way to carry clubs in a non-CM was to lay down one of the rear seats.
Another question in the same vein....does anyone have the measurements of the cargo well under the flat floor in the boot? I need LxWxH. Thank you!
They fixed that problem with the 2013. I for one am glad mine does have one, because I hate run flats and like the ability to pull my tire off to repair it if need be.
