R60 How much is changing engine oil cost?
When it is done outside of the normal maintenance schedule.
Dealers set their prices independently. Don't know if there's any rhyme or reason to it.
Oil changes take a little time and a little skill, but they can be done on your own at home if you're willing, and for considerably cheaper over time.
so 5 quarts, at about $6 a quart....add a $10 filter...., then disposal (or free heating for the shop)....then the customery bmw/mini/any old dealer upcharge= about $75-$100. Simple.
WOW! I knew it was synthetic only, but didnt think it would be that much. I guess being that its required every 5k miles it may actually be about the same as what I pay for my STi... doesnt require synthetic oil.
Key is required....the smart folks who plan on keeping their cars do it every 5000...
not to start another debate, but I guess folks that have a high burn rate of oil could wait....the replenishment (Adding a quart) of the oil will add extra additives...will not remove the contamants, but better than running out or running oil with what is referee to as low tbn (basicly worn out addatives).
I only say do the 5000 mile oil changes because having been a mini owner for a long time, I have seen folks that say the 15000 is what mini sages, so do it ( mini once said cvt tranny fluid was lifetime....then long life....we all know how mini "changed" their minds), but if you plan on having reduced longterm ownership costs, a diy oil change is a cheap ins.
Give this guy a call:
Frank Da Silva
ECP Auto Service - Newark, NJ
12 SOMME ST • NEWARK • NJ • 973-589-5871
Specializes on European Cars and he is a MINI Owner.
Frank works on my R52 because it is out of warranty...Oil Changes are usually under $75. Frank uses European Spec Synthetic Oil recommended for BMW/MINI and uses OEM Oil Filters.
Frank Da Silva
If your hourly rate earnings is hire than the cost for someone else to do the oil change it makes absolute sense to pay someone to do it....
Or if you don't have the tools or location
Not mechanically inclined...takes me 10 minutes to get to ECP Auto Service...puts it on the lift...don't get my driveway dirty...less than half hour to get it done...my hands are clean...don't worry about getting rid of old oil...for under $75 or less.
ECP Auto Service had done SS Exhaust Tips on my CM...Oil Changes, One-Ball Mod, Suspension work, Change RFs, and getting ready to put in a 17% pulley.
