R60 Center Console trim
Old Mar 25, 2011 | 11:08 AM
punkrockdoc's Avatar
punkrockdoc
Center Console trim
So after two weeks of having the car, my wife points out to me that she thought the center console trim is supposed to match the door trim. I have the checkered center console trim, but the door trim is piano black. Looking at the configurator, it looks like it is supposed to match.
I don't mind this mismatch, I actually kind of like it. But I'm just curious if it was a mistake or not.
Old Mar 25, 2011 | 11:19 AM
silvernuke's Avatar
silvernuke
Conventional wisdom would say that's a mismatch.
Well.. MINI obviously thought MINI brand isn't conventional and the mismatch is perfectly normal!
Old Mar 25, 2011 | 11:21 AM
Sealy's Avatar
Sealy
There's a whole thread of outrage and amazement on this somewhere - but I'm too lazy to go find it. Look close at the configurator and you'll see that what you have is what you get.
Old Mar 25, 2011 | 12:37 PM
punkrockdoc
I actually like it, so no outrage here. That is why I asked about it here instead of calling the dealer. I was just curious, because when you select the checkered trim on the configurator, it appears to graphically change the door trim and the center console.
Old Mar 25, 2011 | 12:49 PM
Sealy's Avatar
Sealy
Originally Posted by punkrockdoc
. . . it appears to graphically change the door trim and the center console.
That it does. Changes the door trim from dark anthracite to pianny black and the console from dark anthracite to checkered. Sneaky devils with their fine print and photo magic.
Old Mar 25, 2011 | 01:17 PM
punkrockdoc
Ahhhhh. I see now.
Old Mar 25, 2011 | 02:56 PM
MINIATURIZE's Avatar
MINIATURIZE
Yes, another member pointed this out too, & thanks to you, while it probably wouldn't matter either way, I obsessed about it & had time to change it to the standard trim.
Reasoning: the door trim will match the trim across the dashboard.
The checkered trim is very cool & should be on the doors & dash as well to tie it all in.
Old Mar 25, 2011 | 03:26 PM
Hobie44610's Avatar
Hobie44610
The configurator, which I call the "confuse-a-rator" made a whole lot of trouble for us when we attempted to save our configuration. When we went back to our saved configuration it had mysteriously changed on numerous attempts. Just had to sit down with our MA and plan it out.
Old Mar 25, 2011 | 05:44 PM
Chuckster54's Avatar
Chuckster54
Good to know I'm not the only one having issues with the Mini Configurator. I love website, but can't understand why it doesn't save stuff correctly. Hope to go to dealership tomorrow for a test drive. If all goes well, order will be placed. Exciting times!!
Old Mar 25, 2011 | 06:27 PM
Cosmic Blue Conspiracy's Avatar
I went back and reconfigured after I noticed this on my car, and then read the description. I had assumed I'd get checked across all those surfaces. I LOVE the checkered trim, and it would have kicked much butt to have the doors and dash in check, as well. I'm okay with it, knowing it's not a "flaw" but not the best design choice IMO.
MORENOJM
Sep 20, 2016 08:13 PM
xraycat
Aug 12, 2015 02:36 PM
Aug 7, 2015 05:56 AM
